Terminator Lightning Claws
 Post subject: Terminator Lightning Claws
PostPosted: Tue Sep 07, 2010 11:14 pm
Anyone done any Terminator lightning claws that could give me some advice?
 Post subject: Re: Terminator Lightning Claws
PostPosted: Tue Sep 07, 2010 11:28 pm
Here's my attempt with plastic card. It's basically 4 little strips cut to length and then I trimmed each so that the bottom half is flat/straight and the top was angled/curved to give the curving blade shape.
Here's my attempt with milliput. It has the luxury of the banner behind it to use as a base for the claw. I basically laid the putty flat, cut the blades into the putty then levered the blades up at the end away from the banner for the curve.
Hope this helps anyway. ;)
PostPosted: Wed Sep 08, 2010 2:22 am
If doing them over Chaos Terminators - they have the power glove up the front, I am going to try thin wire for the claws topped with greenstuff - not sure whether it will work however.
There is plasticard, however I am not convinced in it's use for this - Dobbsy did a good job however on his which is making me rethink it's use.
Failing the above, I will start looking in the bits box for stuff to cut up and use for claws.
Hope these ideas help
Cheers...
PostPosted: Wed Sep 08, 2010 10:09 pm
thanks for the info, I was trying to decide whether to use plastic card too. Still a bit undecided yet. This is for the normal none chaso Terminator I am using.
Users browsing this forum: No registered users and 159 guests
