Things to do with the small ruin sections..
 Post subject: Things to do with the small ruin sections..
PostPosted: Mon Mar 17, 2003 1:58 pm
For a break between painting Space Marine Tactical stands and their Rhinos (rather tedious after about 18:{ ), I'm making little bits of terrain with the small wall sections you get on the base sprues. Now, I'm wondering what other interesting things I can make with them, apart from L or U-shapes....
www.darkrealmminiatures.com
PostPosted: Mon Mar 17, 2003 5:26 pm
A short list - on Titan bases; along side road sections; glued to the larger ruins from E40K; form squares and rectangles to make low ruins, add G/W "Arcane Architecture" small windows and the like, to represent doors or big windows. ? :)
PostPosted: Mon Mar 17, 2003 11:15 pm
Thanks Legion 4, well today I made my first bit- a simple L-shape, card mounted, with rubble, flooring made of squares of card cut into various  shapes, some cut in half to look like huge cracked flagstones.... I've then PVA-ed sand to it, painted and drybrushed it to match my desert bases, and added a bit of lichen and static grass to finish it off.
I'm pretty chuffed in the end... :cool:
PostPosted: Tue Mar 18, 2003 5:42 am
That sounds similar to what I do. I'd like to see it. ?I guess with Epic on line, I'll have to borrow my friend's digital camera ??? !?
PostPosted: Tue Mar 18, 2003 9:43 am
The little black ruins I either use for the inside of large ruined buildings, to represent inner walls, or on the bases of Titans.  I have even chopped them a little smaller, so that I can have them on the bases of my dreads.
PostPosted: Tue Mar 18, 2003 1:45 pm
I havn't got a digicam, but yep, I do have a mate with one, so I'll see if I can borrow it sometime to get some pics of my Epic and BFG stuff.. no promises tho :;):
PostPosted: Thu Mar 20, 2003 4:06 pm
The MWDA guys used cardboard that was bent and cracked to give an aged look for pavement, concrete, asphalt. It looks really great.
I would also add that the "mini-ruin" sections make interesting irregular shaped buildings to like hexagons, octagons, etc. Just cut, glue, and add in sand around the joints. It looks good. Another idea is to use a combination of the ruin pieces to build ruins on hills or non-flat surfaces.
Finally, I love using manufactured buildings and adding details to them using plastic sprue, plastisheet, bitz, and assorted garbage. I also use Dollar Store buildings with heavy modification. You'll get unique pieces that look great and they're fun to convert as well.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Fri Mar 21, 2003 1:12 am
Maksim, have you ever made a picture library f all your scenery? I think it would be very cool to make one where everyone could showcase their terrain.
PostPosted: Fri Mar 21, 2003 3:16 pm
Primarch,
No, I have never made a scenery gallery. It's a good idea.
I do have an idea to make a 6mm Consumer's Guide site that would try to catalogue some of the many 6mm models out there.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Wed Apr 02, 2003 6:15 am
I'd love to see sme of the scenary you guys are talkign about- I've just had over 100 sprue sets delivered from GW with my not inconsequential order of Imp Guardsmen...Now what do I do with my 200 (!) small ruin sections...
Tas
Tas
Users browsing this forum: No registered users and 218 guests
