AI airfield measurements
 Post subject: AI airfield measurements
PostPosted: Wed Jul 28, 2010 12:01 pm
I've been brainstorming a bit on a terrain project. Anyone got the measurements for the Forge World Aeronautica Imperialis Imperial Airield pieces. More specifically the landing pads and the control tower?
 Post subject: Re: AI airfield measurements
PostPosted: Wed Jul 28, 2010 12:34 pm
I've got the control tower and the small landing pad. I can take you some pictures and measurements. Might take an hour or two, though.
cheers,
PostPosted: Wed Jul 28, 2010 1:23 pm
Awsome, thanks :)
PostPosted: Wed Jul 28, 2010 4:13 pm
I'm not at work at the mo and not on the forum much these days (20,000 words of dissertation to write in a month, eek) but I have all the different pieces and could measure up the big landing pad (or all of them) for you. I've emailed myself so I hopefully won't forget but feel free to prod me if I do. They are all excellent models.
PostPosted: Wed Jul 28, 2010 5:27 pm
'ere we go:
Image Image
used a base of epic orks for size comparison.
dimensions:
the landing pad has a diameter of about 6cm
the platform for the tower is about 4.5cm in diameter, and the tower itself is around 7.8cm high.
that's it.
best regards,
Markus
PS: warping of parts is optional ;)
PostPosted: Wed Jul 28, 2010 7:01 pm
No pictures sorry but the dimensions of the big landing pad are 15.3cm long, 11.3cm wide, 1.5cm high. All the best with the project!
PostPosted: Wed Jul 28, 2010 8:54 pm
Thanks guys. :)
Well I'm not enturely sure if I'm going to proceed with it, but seeing some of the other fortresses people have been building recently, I really felt inspired to do something along those lines. I've also be meaning to build an airfield for quite some time, so I thought what the heck: Let's try and combine them. I found this at the local store:
http://www.ziterdes.de/ziterdes/en/prod ... ubcatID=68 Which I figured might make a pretty decent (if not entirely cheap) starting point. The detail is a bit crude, but it doesn't have a while lot of scale giveaways so it should be fairly easy to build upon and gubbinize.
PostPosted: Thu Jul 29, 2010 12:15 am
Should look cool!
Users browsing this forum: No registered users and 172 guests
