tamiya paint vs vallejo game colors vs GW colors
 Post subject: tamiya paint vs vallejo game colors vs GW colors
PostPosted: Mon Jan 20, 2003 6:00 am
Has anyone used tamiya or vallejo game colors?
these are the paints that stores around me sell (in addition to games workshops) and i was wondering which is the best? ive only used games workshops.
i can get tamiya paints for 1.89 for 10 ml, but the warstore sells vallejo game colors for 2.79 for 17 ml and game workshops for 1.80 for 12 ml.
thanks
PostPosted: Mon Jan 20, 2003 11:38 am
I used Tamiya paints years ago when making various model tanks, and they were okay then.  I haven't used them on GW materials though, or recently.  Cant see why there'd be any problems.  As long as they are acrylic.
PostPosted: Tue Jan 21, 2003 4:23 pm
Well, Vallejo are what a lot of painters use. They have a range which is so similar to GW that you can easily find the GW colour just by looking at the name. If you can find a regular supply, then I would go with them. I would use Vallejo if I could get them often enough to rely on them!
Are the Tamya paints oil-based? They are thicker, and really for historical miniatures where shading and highlighting are usually a minimum. They are too thick for my use.
PostPosted: Tue Jan 21, 2003 10:00 pm
I have heard that Vallejo's range is better then GW's but I havn't had the chance to try them out myself.
Does anybody know where to get hold of some (the full range, not just a few colours) in the UK?
Currently WAY too busy for his own good!
Bah weep granah weep ninibong
St.Anger is coming....
PostPosted: Thu Feb 13, 2003 11:05 pm
Tamiya paints are pretty good.  They have some very vibrant colors.
They are made to use in airbrushes and are not waterbased.  However, they are compatible with water, so you can use it to thin them while you are working.  I believe they use an alcohol (based on smell and water compatibility).
I'm sure you would get the best results using their thinner.  Based on the fact that thinned oil paints make really good washes because of the very low surface tension, I bet the Tamiya thinned down would do likewise.
I don't think they are that thick starting out, but they do dry and thicken quickly,  It's probably because their solvent is more volatile than water.  In any case, you need to be careful about clumping and your brushes getting sticky.
I hope that helps.  I've never used Vallejo.
PostPosted: Fri Feb 14, 2003 12:28 am
yeah they smelled like alcohol to me to... the jar says theyre acrylic, and from what i remember of my art classes, that makes them water based .
PostPosted: Fri Feb 14, 2003 9:44 pm
Not necessarily.  "Acrylic" just means that is the vehicle.  The pigment and the solvent just have to be compatible.  There are a lot of acrylic polymers, and they can use different solvents.
Also, I forgot to mention, but I think it's obvious, the stickey-as-it-dries makes them unsuitable for drybrushing.
PostPosted: Tue Feb 18, 2003 12:27 am
Location: so close to US Hq I can almost smell it (well, not that close)
There's a paint life beyond GW's paints? I think a problem is marketing these guys. If it wasn't for this, I really wouldn't give them a second look. Where can you find these guys?
You honor me by giving me precise information on everything Games Workshop.
PostPosted: Tue Feb 18, 2003 6:31 pm
Tamiya is available in serious hobby stores in the model sections.  IIRC, they specialize in military colors (browns, greens, grays, etc), but they have a good selection of other colors for people building model cars and stuff.  Try looking near the airbrushes, as they make their paints to work in them.
You might also find them in an art supply store, but probably only if it has a really good selection.
Users browsing this forum: No registered users and 192 guests
