Brown Ink.
 Post subject: Brown Ink.
PostPosted: Tue Apr 27, 2010 11:03 am
I've just run out of the old style GW Brown ink.. anyone know of an ink which is close to it.. tried P3 and Vallejo but they aren't very close matches.
EDIT: Just found another pot of it.. but it won't last forever, so the question still stands
My Photobucket
 Post subject: Re: Brown Ink.
PostPosted: Tue Apr 27, 2010 11:06 am
Seems I'm not the only one who likes the old inks; I stocked up on purple ink before they vanished.
Cote D'arms used to make GW's paints, and do a brown ink which I think is identical to the GW one.
PostPosted: Tue Apr 27, 2010 11:08 am
I use both.. but, for some things the old brown works better.
I was wondering if there was a proper ink, eg Winsor and Newton that was similar
My Photobucket
PostPosted: Tue Apr 27, 2010 11:09 am
I find the new washes are usually better for shading, but the inks were essential for glazing and adding colur intensity.
PostPosted: Tue Apr 27, 2010 1:07 pm
Winsor & Newton Peat Brown works well, but I've never used the Citadel stuff. What is it about the older inks that makes them "work" for you? Flow, color, etc?
Liquid watercolor can work in a similar way & might be worth exploring as well.
WAAARGH!!
The Lost & the Dipped
PostPosted: Tue Apr 27, 2010 1:10 pm
The colour of the Brown is not to yellow or red... also it's a much more intense pigment.. so I can chose how dilute I want it.. the new washes are sometimes too thin.
My Photobucket
PostPosted: Tue Apr 27, 2010 1:27 pm
Yup, the old GW inks were characterised by very strong pigments.
PostPosted: Tue Apr 27, 2010 1:44 pm
Definitely pick up a pot of the W&N & give it a whirl. You typically can't go wrong with proper art-quality goods.
W&N nut brown is probably what you are looking for & the peat brown is a darker color.
WAAARGH!!
PostPosted: Tue Apr 27, 2010 1:49 pm
Not that it helps Ratty's problem but...
I started using Tamiya clear for the lighter colored inks (yellow and orange) a while back because I thought the GW ones were sub-par. I've started replacing my other inks with Tamiya as they ran out. They are vibrant and due to the vehicle they are flexible. They can be thinned with alcohol or water or painted on straight, depending on what effect you're looking for.
PostPosted: Tue Apr 27, 2010 3:20 pm
This is not too helpful, but I found out that Ogre Flesh wash is a milder, or perhaps more dilute, version of the old flesh wash.
PostPosted: Thu Apr 29, 2010 12:55 am
Yeah, the original GW brown ink in the dropper bottle was the best thing since sliced bread. If you find a viable replacement let us all know.
PostPosted: Thu Apr 29, 2010 4:12 pm
I've used very strong cheap instant coffe before.
it's actually a stronger pigment then most brown inks.
but it needs protecting, and I've no idea what the long term look is in terms of colour fastness.
(I'll have a look at one that's two and half years old tonight, but a decade?)
PostPosted: Thu Apr 29, 2010 4:27 pm
As I mentioned before Cote D'Arms used to make the old, old GW paints, and still sell them under their own name, including the old, old inks.
PostPosted: Mon May 17, 2010 1:49 pm
Hoping I'm not too late :)
Check here for a GW Chestnut/Liquitex Transparent Burnt Sienna inks comparison.
Users browsing this forum: Google [Bot] and 148 guests
