Gunsight 101
 Post subject: Gunsight 101
PostPosted: Sun Apr 25, 2010 6:39 pm
Now that the forums are much friendlier to 101 type posts, I thought I'd throw this out. ;) I had it posted on The Waaagh awhile back & it might prove useful to a few folks here.
Step 1: Basically, you start off with a bit of thin copper wire and wrap it around the pointy end of a sculpting tool or something similar in diameter to form a nice circular loop.
Step 2: Slide the wire off, take a bit of plastic screen, & cut out one of the X sections. These will be your crosshairs.
Step 3: Using tweezers, patience, & luck slide the X section of screen in between the wire loop. You may need to slide a razor between the loop to open it more to get the screen in. Once you get the X in place, push the loop together so it traps the bit of screen & hit it with some CA to hold it in place.
Step 4: Clip off the long wire ends, leaving about 1-2mm of wire on the ends of the sight, and use CA to tack it onto your model as you see fit.
I wouldn't recommend trying this after you have had any coffe/tea... ;D
WAAARGH!!
The Lost & the Dipped
 Post subject: Re: Gunsight 101
PostPosted: Sun Apr 25, 2010 6:42 pm
Here's a shot of the finished result on one of my Flakwagonz. The gunner behind it might give you an idea of scale.
WAAARGH!!
PostPosted: Sun Apr 25, 2010 6:53 pm
Positively insane. But very cool nonetheless ;)
PostPosted: Sun Apr 25, 2010 7:47 pm
Yowza!
Now do one on converting the old Battlewagons! Mine aren't up to snuff yet...
PostPosted: Sun Apr 25, 2010 8:09 pm
My thoughts exactly!
PostPosted: Sun Apr 25, 2010 8:17 pm
Isn't is a bit big... I would suggest getting hold of an Electron microscope ;|
My Photobucket
PostPosted: Mon Apr 26, 2010 12:35 am
Spectrar Ghost wrote:
Yowza!
Not to tug my own chain but...http://www.tacticalwargames.net/taccmd/viewtopic.php?f=7&t=13937&start=225
Works good for both chaos and Orks I find :-)
R>
MoK's Painting Blog
Now Showing:
PostPosted: Mon Apr 26, 2010 3:15 am
WOw !! :o :o :o AA sights are usually bigger on AA weapons ... so that's pretty close to scale !! ;D
PostPosted: Mon Apr 26, 2010 5:05 am
Yowza!
R>
Tug on!
Outstanding walkthrough & conversion MoK. 8)
Your LatD still parked at Warhammer World? I'd like to think they have a permanent Epic section, but that might be expecting a bit much.
WAAARGH!!
PostPosted: Mon Apr 26, 2010 11:22 am
No, not still at Warhammer World unfortunately...but they do have a plan to have a once yearly EpicUK display: there's so much good work going on on these forums however that maybe they should seek further!
MoK's Painting Blog
Now Showing:
PostPosted: Mon Apr 26, 2010 7:16 pm
Madness!!!
PostPosted: Mon Apr 26, 2010 7:23 pm
SPARTA!!!
uhm..or TAC_COMMS!!! same same...
Users browsing this forum: Google [Bot] and 148 guests
