Scaling from 40k to epic
 Post subject: Scaling from 40k to epic
PostPosted: Tue Feb 09, 2010 5:34 pm
Hi.
I'm planning to start soon scratchbuilding some chimeras for IG, and I got measures out of the 40k versions, so I can create a nice template on the computer.
Problem is, math's not my strongest asset, so to say, so I have no clue by how much I will have to scale them down for Epic.
Any help? Thanks!
PostPosted: Tue Feb 09, 2010 5:38 pm
40k is 28mm, Epic 6mm.. so devide sizes in 40K by 4 2/3..
My Photobucket
PostPosted: Tue Feb 09, 2010 5:42 pm
40k is more like 30mm these days; that's what forgeworld used for their calculation. They scaled everything at a 1/5 from 40k to epic.
That's what most fan development has used too.
PostPosted: Tue Feb 09, 2010 5:57 pm
I tend to aim for 1:5, but most things i do come out larger than that in the end
PostPosted: Tue Feb 09, 2010 6:38 pm
A 1:5 ratio tends to provide the most pleasing result.
PostPosted: Tue Feb 09, 2010 7:07 pm
Concur, but liberties are taken on an as-needed basis.
PostPosted: Tue Feb 09, 2010 7:13 pm
Agreed, some of the smaller weapons must be scaled up slightly, for example the Heavy Stubbers on the side of my Vanquisher tank's gun barrel are a bit thicker than they should be if scaled on a true 1:5 ratio. As are the lascannons on my Malcafloors.
PostPosted: Wed Feb 10, 2010 3:54 pm
Thanks guys that was exactly the kind of info I needed!
I won't use any 3D/stl wizardry for my project, just plain old plasticard and green stuff + various bits, so weapons and other stuff will be done on a "what's in the bitz box" basis.
But I wanted to be sure I wasn't going to build an army of Baneblade-sized chimeras! :-)
