How to remove infantry from bases?
 Post subject: How to remove infantry from bases?
PostPosted: Thu Jan 28, 2010 2:26 pm
Hi all!
After about 10 years break I decided to go back to wargaming, and to give Epic some love.
I also decided to only stick with plastic models, no metal anymore for me! (Still pending on Resin, though). That'll open up the chances for some interesting conversion projects.
Anyway, the thing is I have several old plastic armies badly painted and stuck to the Space Marine style square bases, which I hate.
I'm planning to paint strip them and transfer them to the new style strip bases, for repainting.
The problem I have is that I cannot find a way to take them off the base without destroying it, which I'd rather avoid so I can reuse it for light vehicles and such. The minis were superglued to the base and the holes are fitting very tightly, so they're quite locked in place.
Anyone got any suggestion?
Thanks!!!
PostPosted: Thu Jan 28, 2010 2:37 pm
Damn! Superglued!? If it was plastic cement, it's a reasonable doddle. But supergluing plastic to plastic!?
:whistle:
PostPosted: Thu Jan 28, 2010 2:59 pm
I can't help you on your problem, but you should -for the future- base your models with white glue.  It is strong enough to hold the model in place yet you can pull them free usually without damaging the base or the model.  It also means that if your stand is coming under undue stress (because of the way it was packed for instance) the model is likely to pop out instead of break.
PostPosted: Thu Jan 28, 2010 3:02 pm
Well, I'd suggest you just buy some plasticard to use to base your light vehicles and get to chopping apart those square bases because, with superglue involved, they're essentially a lost cause.
Any solvents that will de-cure the superglue will have a high likelihood of melting/deforming any plastic they get on.  The time you're going to have to take to carefully remove the models from the bases would be better utilized selling newspapers to buy $10 of plasticard to base other models.  I think you'll find it an *extremely* frustrating experience trying to keep those bases intact.
Best of luck!
PostPosted: Thu Jan 28, 2010 3:44 pm
It depends on the super glue used. If your lucky try soaking them in water around 100-110 degrees then feezing them for an hour or two. The rapid expansion/retraction of the plastic may weaken the glue.
If that doesn't work, get a good pair of sprue cutters, a sharp #11 and destroy the base.
PostPosted: Thu Jan 28, 2010 3:48 pm
A Jewellers saw (available from most model shops) and some patience should do the trick.
MoK's Painting Blog
Now Showing:
PostPosted: Thu Jan 28, 2010 3:51 pm
I gotta ask, how would one use a jeweller's saw to save the base here?
If you're talking about the meticulous cutting around each individual model... man, I gotta ask you why your time is worth so little!  *laugh*
PostPosted: Thu Jan 28, 2010 4:32 pm
Cheers guys,
I guess those bases will meet their maker soon then. And Chroma's quite right, that's a massive amount of time spent there for too little gain.
Actually, the problem is more the tight fitting of the base holes, as the superglue after all those years has become quite brittle. But if I try to force the figures out using a lever, more often than not I end up with a warped base an a broken mini.
And now off to the trade forums to get the things needed to actually finish those armies ;-)
PostPosted: Thu Jan 28, 2010 4:33 pm
The minis are the valuable portion, so I'd skip the headache and destroy the bases.
You can always pick up more Epic squares for your LVs or use p-card.
WAAARGH!!
The Lost & the Dipped
PostPosted: Thu Jan 28, 2010 4:48 pm
Yep ... done it ... cut and file ...  :)
PostPosted: Thu Jan 28, 2010 6:48 pm
aye, I meant merely cutting the minis off and rebasing on an alternative!
Though if anyone remembers my Tyranid debacle...oh boy!
R>
MoK's Painting Blog
Now Showing:
PostPosted: Thu Jan 28, 2010 7:56 pm
You could try drilling a hole right next to the mini (or half through the base, half through the mini's base), then try prying it from there. Puttying up the hole afterward is fairly easy. I think I did that with some farseers and warlocks I had.
PostPosted: Fri Jan 29, 2010 2:38 pm
Thanks semajnollissor, I might give that a go before starting the mad chopping.
PostPosted: Fri Jan 29, 2010 4:06 pm
Again, depending on the superglue, some plastic-safe strippers will dissolve enough of the glue that the infantry will come off. I had some luck with a product called "Mean Green" here in Canada; I think it is a cheaper, perhaps stronger, version of Simple Green.
After soaking for several days in that stuff (be sure to check regularly to make sure there are no adverse reactions) some came off. For those that didn't, I found I could flex the bases (gently, as I wanted to keep them) and other infantry would pop out. I suppose the glue would crack. A sharp pick or sculpting tool that can get under an edge if one appears will allow you to pop them out. You just need a little flaw in the glue. That said, push the model away from you, not towards; the little buggers come out with surprising speed! Also, aim them at something as they have a tendency to ricochet.
If that doesn't work, then it is chopping for you. But I had a collection of about 110 bases that I purchased and stripped, and of that amount, I managed to save about 40 so it depends on how old the glue is, how thickly it was applied and how lucky you are!
Oh, I didn't find hot water worked for me as it just warped the bases (the long E40k ones). The square ones may be more sturdy, though.
Good luck!
