Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
Iron Warriors and Necrons
 Post subject: Iron Warriors and Necrons
PostPosted: Mon Jan 25, 2010 7:16 pm
Thought I'd put up some test paint schemes for my Iron Warriors and Necrons, both in progress. I'm waiting on delivery for many of the items I'll be putting into each army, so posting progress may be slow.
First up: couple of Iron Warriors vehicles:
"Finding new ways to screw up old problems is our specialty."
PostPosted: Tue Jan 26, 2010 7:37 pm
Mate,
A good looking test paint. You might want to look at so e matt ink for the gold areas just to make them a little darker. I have an IW army painted by Onyx. Take a look at his work it is truely enspiring stuff. Anyway welcome to the Legion my friend, always good to see another who is Iron Within.
Aaron
PostPosted: Tue Jan 26, 2010 10:34 pm
Nice work, KaJo.
PostPosted: Tue Jan 26, 2010 10:38 pm
Thanks, guys. I was considering inking the gold; I'll try it out...
I should have the rest of these done by the end of the coming weekend, and my infantry should be showing up in a day or two as well, so I'll have a bit more to post in a few.
PostPosted: Mon Feb 01, 2010 6:45 pm
Got a bit more work done over the weekend: finished the Nashorns and Crabbes, a Zombie Robot War Machine, three pyramids, four angry robot bugs, a big, mean night-dude, and six more stands of wraith conversions.
PostPosted: Mon Feb 01, 2010 6:46 pm
Now if Tom can sober up long enough to get my Edenites out to me, I should have a usable force pretty soon.  :laugh:
PostPosted: Mon Feb 01, 2010 8:25 pm
Fantastic. Great looking armies and good to see some of the Pyramids painted up.
"Stars in my pocket like grains of sand."
www.spartangames.co.uk
PostPosted: Tue Feb 02, 2010 3:02 am
:oo:  Wow. Both these armies are just superb! I would be extremely proud of these if I were you.
PostPosted: Tue Feb 02, 2010 3:28 am
Close ups and a guide on the destroyers and wraiths please?
PostPosted: Tue Feb 02, 2010 5:24 pm
Pretty simple models, really. I used .032" guitar string (decided on a little thinner than the original idea), cut in 25-30mm strips. Bend the string around a round object (such as a hobby knife handle) until you have a crescent. Glue to base.
The torsos are from Dark Realm Andrayada Bodyguard models (they come in the Vanguard pack, but only 4 are in each pack. Contact DRM if you'd like to buy them separately). I clipped the legs diagonally through the torso, starting just under the square gubbin at the base of the model's spine; trim the spike off that sticks up from the model's back. Then trim the front of the torso to better fit the guitar string, and glue.
These I made from the instructions in the Epic Raiders supplement. Start with 40K Necron Scarabs (the plastic ones, not the old metal ones). Clip the head off the scarab, making it flush across the front; trim the little gubbins off the exhaust ports.
Then take whichever model you use for the torso (I used the Vanguard models for destroyers, and the Vulturs for heavy destroyers, though now I believe that the Andrayada Heavy infantry torso would be a better approximation for the heavy), and clip off at the waist. Trim to fit and glue to the scarab.
Both conversions take just a few minutes each. All of the wraiths were completed in  total time of about an hour (getting the guitar string glued to the base without using an accelerant will take a bit of physical support), and the destroyers about the same.
PostPosted: Tue Feb 02, 2010 5:39 pm
That was a brilliant idea, ive also purchased some DRM bodyguards myself after seeing this. Great customer service from DRM supplying the components :agree:
Nice to see a scythe wraith painted as well  :grinning:
PostPosted: Tue Feb 02, 2010 5:42 pm
Thank you.  :D  Besides, everyone knows that painted models perform much better on the tabletop than unpainted models.  :)
PostPosted: Tue Feb 02, 2010 7:43 pm
Hi Kajo, top stuff!
Does the guitar string keep its shape once bent, or do you have to douse it in glue or stuff to make it stiff?
PostPosted: Tue Feb 02, 2010 7:57 pm
Cool Necrons!  :agree:  :agree:  :agree:
PostPosted: Tue Feb 02, 2010 8:13 pm
It will hold its shape, and is a bit springy - it will take bumps and falls without disfigurement.
I should mention the reason for bending the string around a rounded implement - if you bend an angle into the string (as opposed to an arc), you'll not be able to fix it and will need to discard that particular bit of string. Once you've completed a couple of them, it should be easy for you to see how to do it properly.
Edit: make sure you buy a steel guitar string (acoustic or electric - it doesn't matter, since both have a wrapped steel core), not a nylon (classical/folk; wrapped nylon core) guitar string. Catgut is right out (and damned expensive to boot).  :laugh:
