Cutlery monster
 Post subject: Cutlery monster
PostPosted: Wed Aug 12, 2009 3:09 pm
Well, my attempts to create a mascot to promote better use of cutlery around the world went terribly wrong and I ended up with this  :sigh:   however im confident alternative uses could be found.
This is a relatively complex model cast in 11 pieces across 4 moulds, allowing a certain degree of pose-ability:
Torso
2 x blade arms
Rear leg A + toe
Rear leg B + toe
Front leg A +toe
Front leg B + toe
The torso was cast in a 3 part mould and as a result of this it can suffer from serious mould lines on the underside, however there are not really visible once the legs are stuck on. The 3 power rods on the blade arm also cast somewhat unreliably, as long as 2 complete lengths of red cast per arm im regarding it as a success. The rivets and serrations also come out slightly rounded off. The model can be constructed using just super glue, but pinning or green stuff reinforcement makes it far more robust, as does mounting it on a base.
BlackLegion mentioned that it looked too large in the test cast image, however, the model's height and length can vary significantly depending on how the legs are positioned, as shown below.
PostPosted: Wed Aug 12, 2009 3:13 pm
Ooh, ooh, I like it, can I get some?  :))
I sense that in future you will be receiving some PM's - possibly from myself...  :blues:
Great work, by the way  :cool:
PostPosted: Wed Aug 12, 2009 3:15 pm
They do look fantastic.
I wish that I had the skills to create such Epic monstrosoties myself!
I am in need of some new cutlery as I feel as if I need to eat with civilised people.
Can you help me with some 'cutlery'?
In the meantime, that miniature is awesome dude.
PM being sent.
PostPosted: Wed Aug 12, 2009 3:41 pm
Yes just a few..11 in the last 30 mins i think :p
PostPosted: Wed Aug 12, 2009 4:21 pm
The serrations could be filed by end users, of course.
Does the alloy contain lead? Remember to wear your breath mask!
It may be wise to set a few aside in case someone, somewhere, makes something new for a non-ordered trade.
PostPosted: Wed Aug 12, 2009 4:35 pm
Beautiful work. I still can't stand the design of the original FW model, but your sculpting and casting of this is superb.
PostPosted: Wed Aug 12, 2009 4:54 pm
Yes, and the new alloy im planning to start using will be almost entirely lead (+some bismuth to lower melting point). Ive only been using an extractor fan and kept the windows open rather than a breath mask as the product sheet for the alloys states that the lead content of the fumes is negligible at under 500c.
I tested a lead free alloy, and found the castings were extremely brittle :sad: to the extent that you'd snip a piece from the pouring vent lump and it would snap in 3 different places :O
I agree entirly :) , i used to think it was among thier most ugly designs, its grown on me as ive worked on it however. Stretching out the back legs a bit seems to help the overall shape.
PostPosted: Thu Aug 13, 2009 1:13 am
I absolutely love it!  :wow:
And with "to big" i meant it isn't a 1:5 reduction of the Wh40k model. But it has the right size in comparison to an Epic Dreadnought. For the FW Grey Knights Dreadnought which is a 1:5 reduction of the WH40k model the Cutlery Monster would be to big (the Epic Dreadnought is rougly 20% bigger than the FW Epic Grey Knights Dreadnought).
But i certainly won't blame you! Becaue:
1. You did this only with pictures, no actual model!
2. Your modelling skills far outpace my skills!
3. It is a piece of beauty!
Kepp up the good work  :D
PostPosted: Thu Aug 13, 2009 4:01 pm
Dobbsy, your cuttlery is ready but your inbox is full :p
PostPosted: Fri Aug 14, 2009 1:47 am
I really want to see the cutlery monsters Greater Arachnid friend now....
Chaos Titan Legions: Khorne
Chaos Titan Legions: Nurgle
PostPosted: Tue Aug 25, 2009 7:47 am
Thanks Apoc! I received my Cutlery today!  :agree:  The only question I have is how do I put them together? There are a few different types of legs/blades included however there are only 4 of the small, front "Z-shaped" legs with the stuff you sent. Are there supposed to be more for 6 monsters?
Do you have a "putting them together" tutorial by any chance?
PostPosted: Tue Aug 25, 2009 8:19 am
gah...yes there should be 6 z-shaped front legs for 6 monsters, my apologies, ill cast you 2 more (wont be casting again till copper arachnid moulded, which should be 1-2 days). The Z-shaped front legs can glue on anywhere to the front of the the disc at the bottom of the torso, the long rear legs glue onto the two protrusions at the lower back of the torso (again grenstuff/pinning recommended.
If you require additional assistance i can draw a diagram. Sorry for the inconveniance, the masters were not made with ease of assembly in mind  :blush: (although i have tried to modify them a bit to aid that)
(also please ignore the PM i sent yesterday, its all resolved now)
PostPosted: Tue Aug 25, 2009 9:04 am
Ahh! good to know! Thought my modelling skills had dropped way down.  :vD I figured the front legs would go on the crossbar section under the chin. Glad you filled me in.
So 1 pair per monster then? That makes front legs for 4 monsters to go then  :agree:
Thanks for the speedy response.
PostPosted: Tue Aug 25, 2009 9:15 am
how many z shaped front legs do you have? :sus:  each cutlery should have 2 long back legs (+2 small toes/blades), 2 smaller front legs (+2 small toes/blades), for a total of 4 legs per monster (+2 blade arms). There should be 11 pieces total per monster.
Users browsing this forum: No registered users and 193 guests
