Help me make some tunnelers
 Post subject: Help me make some tunnelers
PostPosted: Sat Jul 11, 2009 6:56 pm
Hi guys,
My latest project is just about drawing to a close (an epic Leviathan for my Skitarii with pics/thread to come) and I quite fancy continuing with a mechanicus feel.
I really fancy making some tunnelers (probably the equivalent of Moles/termites) which I can reverse mount (yes cowgirl style) on the back of old deathstrike missile carriers.
The trouble I've had is that I can't find anything plastic, pointy and with a screw thread, so I'm looking for suggestions.
Can anybody think of anything that would fit the bill? The closest I've come up with are wall plugs but I haven't found a suitable one yet.
Thanks for any responses
PostPosted: Sat Jul 11, 2009 7:12 pm
The tunneller from the EW Mining Machine would fit perfectly. However buying the entire machine just for the tunneler is probably overkill  :sad:
http://www.exoduswars.com/store/khazari ... i-267.html
PostPosted: Sat Jul 11, 2009 7:40 pm
Yes ... that's what I was going to suggest ... E/W Tunnellers ...
PostPosted: Sat Jul 11, 2009 7:42 pm
Tom did mention at one point he was considering making just the tunneller buyable separately for proxy purposes.
PostPosted: Sat Jul 11, 2009 10:11 pm
You're close with rawlplugs.
Plasterboard fixings have a nice chunky screw thread to them:
http://www.diytools.co.uk/diy....ngs.asp
My shifting projects
PostPosted: Sun Jul 12, 2009 12:08 am
The tip of a fairly large screw stuck onto a piece of pastic tubing with some smaller pieces of plastic rod at the bottom should do the trick. Stick on a FW brass etched Imperial eagle and a small circle of plasticard for the hatch and it should look decent. A bit more work than buying a finished piece but certainly more economic :)
PostPosted: Sun Jul 12, 2009 12:40 am
You're right WM
From experience though screws are bloody hard things to
a). clamp into a fixed position
b). Saw through
if anybody has any finger saving tips on how to do this I'm all ears.
I thought I was onto something earlier trawling ebay for plastic toy DIY sets but it's all rounded edges and 'ealth 'n' safety.
Best I found was a guy selling the drill piece from this
A little on the large side though.
PostPosted: Sun Jul 12, 2009 12:55 am
Agreed. Screws are a real B**** to work with. I'm not sure if Lego has anything screw like that is less than 1 cm in diameter but I wonder if some kind of plastic toy screws exist? There must be some kind of toy carpenter kit available somewhere...
PostPosted: Sun Jul 12, 2009 4:12 am
As a termite - yes
Too small to be a mole.
PostPosted: Sun Jul 12, 2009 9:33 am
what diameter and length are we looking for?
PostPosted: Sun Jul 12, 2009 9:49 am
Measuring things before I build them is a little Alien to me.
Looking at the chasis I was thinking of using something with a nody about 2-2.5 cms long with a drill piece 0.5-1 cm ought to work well. Diameter wise I reckon something quite big like say clicky biro would work.
PostPosted: Sun Jul 12, 2009 4:09 pm
ahh. I've actually got some that size, am using them for my neo-squats.
as an example
http://www.thesitebox.com/Categor....gs.aspx
Any DIY shop should stock them.
It's a big metal (or nylon) screw that has a hole for a real screw to then go into it.
PostPosted: Mon Jul 13, 2009 3:08 am
You can get decent looking plasterboard fixing screws in plastic.  Not certain but I'd say they are actually polystyrene to boot.
Fire bad, tree pretty - Buffy
PostPosted: Mon Jul 13, 2009 3:40 am
Those Lego drill bits can be picked up separately  HERE
I think you can actually get them ordered direct from the Lego site along with other possibly suitable bits.
*edit* Ok that link might be borked, but check eBay for the Rock Raiders drill bits.
WAAARGH!!
The Lost & the Dipped
PostPosted: Mon Jul 13, 2009 3:07 pm
Fixed link:
- George Borrow
Users browsing this forum: No registered users and 150 guests
