How to make 1:5 scale dreads
 Post subject: How to make 1:5 scale dreads
PostPosted: Sat Jun 20, 2009 9:33 pm
Here is a simple step by step guide to making 1:5 scale scratch build dreadnaughts. SG dreads are towering 16mm tall from toe to exhaust (over 2 epic infantry tall), while a 40k dread (or the AOBR plastic at any rate) is around 550mm tall (under 2 40k inf tall) this is an attempt to make more accurately sized dread. Finished dreads come out about 11-12mm tall, so pretty much 1:5 scale.  The same method can be used to make Mark IV dreads, Mark IV chaos dreads, iron clad dreads, venerable dreads, chaplain dreads and probably a throne of judgment.
Per dread You will need the following:
about a postage stamp sized area of 1mm plasticard in total
2.5mm of 2mm plastic tube (+2.5mm per power fist, +3mm if Mk IV/chaos/venerable/chaplain)
A selection of thin plastic rod (i use 1mm, 0.8mm and 0.6mm)
4mm thick, 3.5mm tall standard GW sprue
The ability to cut out rectangles is also pivotal...
Stages:
1) Feet – (make these first as off cuts are needed later). Cut some 4mm square bits of 1mm thick plastic. Cut a 1mm square from each corner (keep the bits). Slice the edge of each of the toes thus formed into a slight angle
2)Armour (a) cut a 5mm length of sprue.  Cut out two 4 x 2mm rectangles and two 2.5 x 2mm of 1mm plastic, cutting a 1mm square from one corner of each larger rectangle. Stick the smaller rectangle  at 90° onto the back of the larger, on the end without a square cut out (b). These are the front and top armour plates, stick them onto the sprue ©, with the smaller rectangle on the thinnest (top) face of the sprue and leaving a 2-2.5mm gap between the two plates (d).
3) Sarcophagus- cut two 5mm x 2mm rectangles of 1mm thick plastic, glue on top of each other. When dry cut a very steep angle at one of the thin ends and a shallow angle at  the other. Stick this onto the side of the sprue between the armour plates from the last stage , with the steep cut end on a level with the thin (top) of the spue, the bottom of the sarcophagus should protrude about 1mm past the bottom of the sprue.
4) Exhaust – cut a 3 x 2mm rectangle of 1mm plastic , stick two 1 x 2mm rectangles on top with a 1mm gap and cut an angle along the long edge these small rectangles. Stick this block onto the back of the sprue (eg opposite side from sarcophagus), decorate top with two small slices of rod for exhaust pipes)
5) Hips & decoration– stick two 4 x 2mm rectangles of 1mm plastic together, cut an angle down the ends to form a trapezium. Stick this to the underside of the sprue. Using the 4 1mm squares cut from the feet, cut one into a small trapezium and stick it to the back of the hip block (centred) . Stick one square centred to the front and one underneath, pop the fourth between the armour plates on the top of the torso. Stick some small blocks of 1mm plastic onto the sides of the sprue as well, the arms will stick onto these.
6) legs – cut two 5 x 1.5 mm rectangles of 1mm plastic. Round one end off. File/cut a small incision about 1mm down from the rounded end. Stick a Small slice of rod on one side.
Leg armour – cut two 2.5mm length of 2mm tube. Make a pair of angled cuts into the side of the tube at the top. Slice the tube down in half, giving you two curves shin plates. Stick the shin plates on the front of the leg rectangles, stick a foot on the bottom of the leg. Stick the legs onto the hip block.
7) Arms – so many variants, but the main block of a normal shoulder is just two 3 x 4 mm rectangles of 1mm plastic stuck together with one corner cut off at an angle. Then proceed to attach bits of rod till guns appear! (for a power fist thing use 2mm tube).
PostPosted: Sat Jun 20, 2009 9:35 pm
Mark IV, chaos, venerable and Chaplain sarcophagus:
cut a 5mm x 2mm rectangle of 1mm thick plastic. Cut a 2.5mm piece of 2mm tube, slice it in half lengthways, stick it onto a face of the rectangle about halfway up. Cut a thin slice of 2mm tube (say 0.5mm) and slice a small section out of its circumference, stick this curve onto the top of the rectangle, end on, above the 2.5mm curved section. Insert a green stuff head of choice ( not shown) . Stick to front of dread in place of normal sarcofogus)
More examples (ive made 20 total now, with a few missing guns still):
PostPosted: Sat Jun 20, 2009 10:00 pm
Marvellous. :grin: Where'd I put me plasticard?
PostPosted: Sat Jun 20, 2009 10:10 pm
Brilliant work!
PostPosted: Sat Jun 20, 2009 10:15 pm
hmmmmmm.rectangles you say?
My shifting projects
PostPosted: Sun Jun 21, 2009 12:36 am
:D
Some pepole really have gold fingers !
PostPosted: Sun Jun 21, 2009 1:26 am
Nice work  :agree:
Having recently bought some Grey Knight's ones I appreciate how over-sized the SG are:
I hope someone CADs generic marine dreadnoughts in truescale at some point, else I may try to convert some Grek Knights ones to be proper sized normal ones.
PostPosted: Sun Jun 21, 2009 9:15 am
Wow - terrific job, that  :cool:  :cool:  :cool:
Back from oblivion (again)?
PostPosted: Sun Jun 21, 2009 4:10 pm
I'm loving how to make a Multi Melta actually...
PostPosted: Sun Jun 21, 2009 4:23 pm
I wonder whether this'd make a good article for Bell of Lost Souls.
PostPosted: Sun Jun 21, 2009 4:54 pm
Wow! You are really insane :D
PostPosted: Sun Jun 21, 2009 5:47 pm
Good and clear tutorial, thanks! Fantastic looking models.
Rats Keep Running...
Dark Eldar Dracon
PostPosted: Sun Jun 21, 2009 8:06 pm
The tutorial's brilliant!!
Is there any chance of a diagram showing the shapes cut out to scale (so I can be lazy and print that out onto plasti-card)?
Also the first point about feet confuses me
Your feet are square looking but this would produce rectangular toes? should it be 3mm square to start with or 1.3 mm square pieces removed?
PostPosted: Sun Jun 21, 2009 8:48 pm
...Also the first point about feet confuses me...
Correct, the squares i cut out are a bit bigger than 1mm, but i didn’t measure it when i did them, i just went for what looked good – so yeah 1.3mm squares removed from a 4mm square. :)
I have all the bits drawn to scale already (guess what, you can make enough bits for over 200 dreads from an A4 of 1mm plastic...) but assumed they’d be removed if i posted them as GW seem to terminate any nets/plans openly available online for their stuff (fair enough).
Another thing i missed in the tutorial is that to counteract the slope on the back of the sprue where the power plant is you need to stick a small, thin spacer between the top of the power plant and the sprue (i used a 1 x 3mm bit of ice cream tub lid). MkIV dreads also need double exhaust pipes.
Users browsing this forum: No registered users and 176 guests
