Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 40 posts ]  Go to page 1, 2, 3  Next
What should E&C make next?
Modern Bombard Design (based on a Leman Russ hull like the Forgeworld one for 40k) 100%  100%  [ 6 ]
Total votes : 6
 Post subject: What should E&C make next?
PostPosted: Sun May 17, 2009 1:39 pm
After I've finished my Vraks projects, what model should I make?
PostPosted: Sun May 17, 2009 1:43 pm
I vote bombard, seeing as the current epic bombard is now a colossus...
Though my guards may sleep and ships may rest at anchor, our foes know full well that big guns never tire.
The Armoury
PostPosted: Sun May 17, 2009 1:46 pm
I would say Truescale Warlord Titan (Lucius!!!!!!!!)
PostPosted: Sun May 17, 2009 2:05 pm
I voted warlord titan weapons, with the proviso that you let me scribble up a couple of sketches for input. :))
PostPosted: Sun May 17, 2009 2:13 pm
I actually have a vague plan if I go with 'Warlord Weapons' that'll let them also be compatible with an Ordinatus Minoris.
Basically they would consist of:
Left Arm & Weapon Shield.
Right Arm & Weapon Shield.
And a bunch of plug-on modular weapons.
Those modular weapons would use the same mounting point as a hypothetical Ordinatus Minoris, and possibly even the same mounting point as the carapace weapons on the Warlord Titan.
PostPosted: Sun May 17, 2009 2:59 pm
Its one of my pet hates about the new warlord, I can't image a gatling blaster or whatever looking good on the carapace mount :(
Missile launcher, sure, but I still can't picture it. I'd love to see what you come up with though  :)
The Armoury
PostPosted: Sun May 17, 2009 3:27 pm
Well if you follow what they've done in Warhammer 40,000, only certain weapons (Warhound weapons, Support Missiles & missile launcher) are allowed on the carapace.
PostPosted: Sun May 17, 2009 3:36 pm
I voted that you should stop, because you make me look bad.
But seriously folks, all of those sound good.
PostPosted: Sun May 17, 2009 4:05 pm
i didnt vote cause i dont care what you make next, as long as you keep making stuff !! :p
PostPosted: Sun May 17, 2009 4:11 pm
The Boyz here seem to have the "hots" for Titan stuff ...  :))
PostPosted: Sun May 17, 2009 8:11 pm
If its guard or guard related I would want some, so really does not matter to me :grin:
There is no such thing as friendly fire, it is all bad!!
PostPosted: Sun May 17, 2009 8:12 pm
Ordinatis Minoris, please!
PostPosted: Sun May 17, 2009 8:15 pm
It depends on how much you intend to include on the 'plug-on' bits.  Just distinctive muzzles, or substantial amounts of the inside 'forearm'?  The former wouldn't look very good, IMO, and there could be problems with interchangeability between substantially different weapons.  E.g. fitting a chunky powerfist onto the same slot as the three thin barrels of the FW inferno cannon.
I'd be happier if the modular parts included most of the inner surface of the forearm.  This'd make it easier to include weapon-specific parts like ammo/fuel storage and certain feeds and pipes.  Take a look at the FW titan weapons and see how different they are from end to end.  But that'd be even easier to incorporate, and I'd personally prefer it, if any modularity in titan arm weapons happened at the shoulder...
I was thinking of trying to convince you that a modular design with interchangeability between carapace hardpoints and minoris would be the way to go, but IIRC ordinatus minoris can pack a wider range of weapons than carapace points.  True?
PostPosted: Sun May 17, 2009 9:02 pm
True?
True, Minoris units can mount any Battle class weapon, which means arm weapons.
This is a quick sketch of the kind of modularity I'm thinking of...
PostPosted: Sun May 17, 2009 9:03 pm
Doing it that way would keep production costs to a minimum, otherwise you'd have to do right arm/left arm versions of all weapons, for example, and you'd need a new third cast to fit on an Ordinatus Minoris or a Carapace slot.
This concept would be able to fit left, right, carapace or Ordinatus...
Swapped...
Users browsing this forum: No registered users and 172 guests
