E&C Tries out Rapid Prototyping
 Post subject: E&C Tries out Rapid Prototyping
PostPosted: Fri Mar 27, 2009 11:16 pm
I'm going to have a go at this Rapid Prototyping lark.
I've decided to start simple, with a Sponson & Battlecannon conversion kit for the Forgeworld Leman Russ, in order to make it compatable with the E:A rules.
Here's what I've done so far:
PostPosted: Fri Mar 27, 2009 11:19 pm
Looks good so far. And a much needed conversion bit I might add :)
PostPosted: Sat Mar 28, 2009 12:39 am
looks good E&C
http://s266.photobucket.com/albums/ii249/kev101/
PostPosted: Sat Mar 28, 2009 2:51 am
can i ask a dumb question?
how is it you guys make these sketches, or whatever you call them? is this something that can be done on a home computer (assuming i had any artistic talent)? or this some type of drafting computer?
sorry if this is a bit off topic. looks great so far and agreed it a useful piece.
PostPosted: Sat Mar 28, 2009 3:21 am
It can be done on any PC. A good video card helps, but isn't absolutely necessary. The main cost is the price of the 3D software. The are a few free packages, but I don't know how good they are. regardless of price, most software has a steep learning curve (figuring out the commands that will produce the shape you want).
I use Autocad, because I have access to it at work. It's a pretty terrible package for artistic 3D work (and even technical 3D work) but it gets the job done and I am familiar with it. I think 3D studio max is pretty popular, but there are loads of others. Inventor, Pro/E, Catia, etc. are all more engineering/design slanted, while 3d Studio, Blender, etc are more artsy.
At the most basic level, most of the stuff isn't too hard to draw. Draw a cross section, extrude it to the right length, ad nauseam. Some bits are a bit more complex, but not by too much. Having a part in your hand to measure and copy makes it even easier, which means making a real-world mock-up quite useful.
PostPosted: Sat Mar 28, 2009 3:32 am
Just a normal home computer, and some 3D program that can output in STL format. I use MoI (www.moi3d.com).
Speaking of which, E&C, what program did you use?
PostPosted: Sat Mar 28, 2009 8:39 am
Rhino.
It's ok if some objects overlap isn't it?
PostPosted: Sat Mar 28, 2009 9:55 am
I second that, I would love to kit out my forgeworld Russes with Sponsons, they look kinda naked without them
Rocking it since 1975....damn, I am old
PostPosted: Sat Mar 28, 2009 3:23 pm
Another stupid question, but how do you make real stuff from the 3d stls?
and have you made a repository somewhere of finished stuff you guys do?
PostPosted: Sat Mar 28, 2009 4:22 pm
Rhino.
You will need to boolean union all of the pieces together into a single solid.
PostPosted: Sat Mar 28, 2009 4:24 pm
Ah that should be easy then.
PostPosted: Sat Mar 28, 2009 4:28 pm
We use 3D print services. We upload the file and some money, they own the machines and do the printing, then they ship the finished thingy.
I recommend PrintAPart in the US - excellent resolution, about $10 per cubic centimeter.
PostPosted: Sat Mar 28, 2009 5:36 pm
again e&c i'm sorry for getting way off your original topic. but otterman when you say $10 a cubic cm do you mean for the mold or for each piece?
PostPosted: Sat Mar 28, 2009 5:45 pm
For the print / piece. You have to learn molding for yourself.
PostPosted: Sat Mar 28, 2009 6:25 pm
thanks, that's what i thought.
now back to your regularly scheduled program....
Users browsing this forum: Google [Bot] and 192 guests
