[Proxies] Termites, Moles, Hellbores and Carriers
 Post subject: [Proxies] Termites, Moles, Hellbores and Carriers
PostPosted: Wed Mar 25, 2009 10:32 pm
So to add to the long list of proxy threads we have... anyone got ideas on these?
Personally, I have a ton of Termites and a few moles, but no carriers for either.  I also have a Hellbore with carrier, but the tracks are missing.  Obviously, I'm especially interested in any carrier proxies that don't involve a large quantity of conversion.
PostPosted: Wed Mar 25, 2009 10:43 pm
You could use the E40k/E:A Deathstrike launch vehicles perhaps?
Granted, the tunnellers would enter the ground off the back of the vehicle and not the front, but I doubt that's a big issue. Otherwise, you could always mount the tracks backwards on the same models to get a more 'traditional' launching platform (i.e., off the front).
If you can't get hold of enough Deathstrike launchers, Griffons or Basilisks would work well, and you could easily add a little plasticard rectangle for a launch ramp with a piece of paper clip to denote the hinge.
The hellebore tracks are still available BTW. I think it was an old M113 APC kit that GW licensed the tracks from; the vehicle is still made by the original manufacturer (and is cheap), so if you buy the kit you get the tracks.
+++ EDIT +++
The tracks for the CI and the Hellbore apparently came from a JB Models M113 ACAV or M113 Fire Support, and the scale was 1/76. Hope that helps!
Quote: (Warhead @ 08 Mar. 2009, 10:33 )
*...Blinded by awesomeness, Warhead can't see the keyboard to type his overwhelmed feelings of wonder... He hits emergency "too cool" button!...*
+++EMERGENCY! THIS IS TOO COOL! DROPPING RAY SHIELDED BLAST DOORS+++
PostPosted: Wed Mar 25, 2009 11:21 pm
IIRC there is a hellbore carriage up on Ebay UK right now. Just the plastic track assembly though.
-Vaaish
PostPosted: Thu Mar 26, 2009 12:05 am
Deathstrike Launchers are definitely the best way to go. But if you have a LOT of termites it could get expensive very fast. A cheap solution could be to use old plastic MK 1 Land Raiders with the sponsons cut off and a small strip of plasticard added as a ramp. If you want the termite mounted lower you could tage a round file (is it called that in english too?) about the same diameter as the termite and carve into the hull of the tank until you reach the desired depth. I would reverse the Land raider hull so it looks slightly like the shape of Leman Russ tracks. I actually think that could look pretty good while still being very inexpensive.
A Forge World Trojan with a similar treatment would work just as well i you want a  more detailed miniature. For the Mole I think something slightly bigger might be appropriate. If you don't fancy carving up an expensive GW or FW super heavy, the EW enforcer is reasonably cheap and has a flat top that is easy to convert. For the ramp you could use cable ties to get a surface texture close to the original model.
