Crimson Skies
 Post subject: Crimson Skies
PostPosted: Thu Jan 22, 2009 6:49 pm
Has anyone seen the Crimson Skies aircraft and can say how they will fit in with Epic as an alternative airforce for the Empire?
PostPosted: Thu Jan 22, 2009 7:41 pm
There was some discussion about that here:
http://www.tacticalwargames.net/forums....crimson
I would think they'd look better as ork craft than Imperial, but some of the planes would be alright.
I think there are two scales of CS planes, too. The original metal models are slightly smaller than the later, pre-painted ones
PostPosted: Fri Jan 23, 2009 10:46 am
Thank you, I have looked at the range and they have some great aircraft for both forces but they will fit in well, design wise, with an Imperial Guard force I am planning.
PostPosted: Mon Jan 26, 2009 2:18 am
I use some of the pusher prop planes for my oek AI force.  I cut off the props and drilled out holes to make them jets.
I found the metal ones from Ironwind metals good but a bit on the small size compared the FW flyers.  They would be perfect with the standard GW flyers.
The clicky Crimson skies aircraft from Wizkids were a better fit, but they are only avaliable from ebay and such.
Thread with pics
Users browsing this forum: No registered users and 212 guests
