Scratchbuilt things
 Post subject: Scratchbuilt things
PostPosted: Tue Feb 26, 2008 5:08 pm
Hello everybody!
As I have completed a stage in the process of creating tyranid proxies, I could think things over and decided to start something drastically different from sculpting in 6 mm. I have always been fascinated by the Imperator titan, but sadly, I have so far been unable to purchase one (I mean one that's relatively cheap). I have been craving for it, but nothing happened, until I had an idea.
When I first got into the hobby, I started with WHFB, and right at the beginning of my carrier as an orc warboss, I committed the ultimate blasphemy: I built an orc lobba from three plastic ice-cream spoons (from a well-known fast food restaurant). I put orcish things on it, and I even painted it, but it was of course well recognisable. Even so, that piece of warmachine was the only thing in the army that never misfired and always hit (it has only scattered onceso far; right on top of the enemy High Elf general :D ). Apparently, my "MCLobba" appreciated all the work and caring love I had invested into him, and rewarded me with a lot of squashed things on the battlefield. Now I collect mostly EPIC, but the question is present: would some warmachine work better if I build it myself from something utterly scratchy?
This idea has made me create something that looks totally funny (or revolting) at first, but it is crazy enough to work on the battlefield. The first result of the mad techno-priest that lives in me: Timothy the Imperator. The legs are made of two ball-point pens and plactic tubes that used to contain dissolvable vitamin tablets. the torso was built from Kinder egg toys (I don't know if they exist in the USA, they are chocolatae eggs with some small plastis toy parts under the chocolate casing). The "plasma" weapon is the shoulder rocket of some old Transformer toy (a Dinobot, i think). the towers are again plastic spoons, and if you look closely, you can actually see a genuine GW component in it too: the devotional bell is a skaven bell from a fantasy command sprue. I still have to work on it a lot (and I DO mean a lot, especially on the legs), but you can get the general idea.
(I only wonder what kind of machine spirit can get into this titan ??? )
I am going to make some more warmachines like that: I even have a set of rules for them.
1) I will not use GW parts, or even actual modelling bits if I can help it.
2) The more impertinent the model, the better.
3) The outline of the model should resemble the original one if there is an EPIC version of it.
4) If I use GW bits, they should be used up in a sense that they were not meant to be (like, I don't know, taking a 40K bolter, and turn it into a plasma drive for a BFG ship,you know what I mean).
5) As scratchy as possible. Nothing fancy, not Golden Demon, just to get the message through even on the tabletop.
Please tell me what you think of this idea or of Timothy himself.
PostPosted: Tue Feb 26, 2008 9:29 pm
Go, Clobbersaurus!
What are you waiting for? Get that guy primed up and drybrushed!
PostPosted: Tue Feb 26, 2008 9:51 pm
I'm with O-man, what are you waiting for?  :D  Add some weapons to the carapace and you'll be ready to paint it.
PostPosted: Wed Feb 27, 2008 1:46 am
Looks like a Winner ! :D
PostPosted: Wed Feb 27, 2008 8:51 am
It distrubs me on so ma ny level. I love it. :D
Tyranid air marshal
PostPosted: Thu Feb 28, 2008 5:33 am
Probably the 2nd or 3rd best bit of scratchbuilding I've seen today!
Fire bad, tree pretty - Buffy
PostPosted: Thu Feb 28, 2008 9:21 am
great!!! very inspiring!!
I want to see more !!
Riau!!!!! O_o!
http://elbansblog.blogspot.com/
PostPosted: Thu Feb 28, 2008 11:07 am
Ingenius
PostPosted: Sat Mar 01, 2008 7:20 pm
Thank you very much for the kind words. I have just had a look at Timothy, and I think the angle of the picture was not perfect. Here are some more pictures, the first being its back. There is a really big fusion power pack on its back, and the pens that form the leg are more visible.
PostPosted: Sat Mar 01, 2008 7:35 pm
Next, here is a picture showing the "castle section". The crenallation (I think this is the name though I am not sure) is actually made from the leftover bits of a 4-part sprue containing fantasy square bases.
I will probably start working on the legs soon, only not right away as I am still waiting for the result of my tyranid gaunt sprue project. Also, I have started playing regular EPIC matches with another guy, and I need to expand my CSM army first. Consequently, the next "scratchy" item will be some form of defiler and maybe a death weel. I have already collected the bits necessary for the defiler: old version plastic Night Goblin arms holding bows, some 4-piece round base sprues, skulls, 40K tyranid gaunt heads and an earpick. ???
Update in a few days.
PostPosted: Sat Mar 01, 2008 11:58 pm
Yes, IIRC, Crenallation" is correct !  :)  Look forward to seeing the old boy painted !  :D
PostPosted: Wed Mar 05, 2008 7:33 pm
Hello everybody!
Timothy's legs are undergoing construction right now; I will cut out the shape of the gothic entrance legs from thin plastic sheet, glue them onto the legs, and put some more GS on to raise out the arches. In the meantime, I am trying to put together a very basic defiler type. Here is the material I used. The white rod in the background is from an earpick. I didn't know they all come out hollow, but i needed a flagpole, and when I removed the cotton, it turned out they are all hollowed out and glue perfectly. The "torso section" is the bit that holds together the round slottabases, while the "talon legs" are the top and bottom parts of old plastic night goblin bows (I guess any other kind of bow would do). I needed to cut the top of the "talon" as you can see on the foremost piece.
PostPosted: Wed Mar 05, 2008 7:38 pm
This is the machine I could put together from the above material. The head is too tyranid-like, but I am going to add a pair of horns and also some side weapons. The horns will probably be new one-piece night goblin bows, and the side weapons... I don't know. Maybe BFG chaos batteries.
PostPosted: Wed Mar 05, 2008 7:46 pm
Nice, I like it.
PostPosted: Wed Mar 05, 2008 8:24 pm
Good grief - I'm beginning to love this stuff :) :) :)
See, I'm not the only one who uses any old stuff to make models :) :)
Like the Defiler, in particular. I'd recommend blending the gun with the head with green stuff to reduce the Niddyness.
Side weapons... ummm - a quick and easy one would be a pair of rocket launchers made of cotton bud (cotton tip?) plastic tubing cut in short lengths and glued together to make a multi-barrelled launcher.
Back from oblivion (again)?
Users browsing this forum: No registered users and 206 guests
