3D blast markers: Where to get them?
 Post subject: 3D blast markers: Where to get them?
PostPosted: Thu Jan 03, 2008 3:32 am
Can anyone suggest a good online supplier of 3D blast markers?
I tried making my own but it was all junk.
Cheers!
Tepoc
___
Beware the fury of the Bahazikhaine!
http://www.pbase.com/tepoc/epic_army_pics
PostPosted: Thu Jan 03, 2008 4:14 am
Litko is the most common recommendation I've seen, eg:
http://www.litkoaero.com/page/LAI/PROD/TS/TS027-SM
Or if you want to have another go at your own see dropship here:
http://www.dropship.org.uk/epic/ter001.asp
I made mine as follows.
50 blast markers done using the steel wool technique. It is possible to sculpt artful mushroom clouds and explosions with bits flying everywhere, but I wanted lots done fast! Technique used took about 2 hours and involved the following:
1. Tufts of steel wool glued to counters, and then sprayed flat black.
2. Edge of base painted in earthy colours (don't do this if you want to use them for BFG as well!).
3. Bottom of explosion drybrushed white, then white drybrushed yellow (white helps bring out the yellow but it's not really necessary).
4. Red drybrushed over yellow with more red concentrated towards the top (note many people get this the wrong way around - flames are red on top and yellow and white below - so to paint flames you reverse highlight).
The sequence of painting the BM can be seen in the lower right of the photo:
PostPosted: Thu Jan 03, 2008 3:41 pm
I think those linked above are flame markers, there's these though:
http://www.litkoaero.com/page/LAI/PROD/TS/TS011
Moscovian uses them from memory.
PostPosted: Fri Jan 04, 2008 2:26 pm
Reaver makes some fantastic 3D blast markers. But where is he? I miss him.
PostPosted: Fri Jan 04, 2008 3:26 pm
I do use the Litko and I love them.  Good prices, three different sizes, fast shipping.  I can't say anything bad about the experience except...
Don't use superglue on them.  Use tacky glue / Elmer's Glue to hold the pieces together.  The superglue etches the plastic.  But that isn't Litko's fault - I should have known better gluing that type of plastic (it is similar to the Necron glowing rods).
Users browsing this forum: No registered users and 153 guests
