Need Measurements
 Post subject: Need Measurements
PostPosted: Fri Aug 24, 2007 5:34 pm
simply need the measurements in CM on an epic scale plague tower, and maybe a good close up shot of a painted one, as im making one for my deathguard in 40k scale.
thanks alot
PostPosted: Sat Aug 25, 2007 12:32 pm
anyone? just a lil help?
PostPosted: Sat Aug 25, 2007 8:15 pm
Now that I'm home I can take some measurements for you.
The base is about 1.75 in x 1 in (4.5 cm x 2.5 cm). The tower itself is about .75 in wide x 1.25 in, counting the length of its weapons, x 2 in tall, counting the height of the bell (1.5 cm x 3 cm x 5 cm).
PostPosted: Sun Aug 26, 2007 1:04 am
so the entire demon engine is 5 CM high? how tall is a basic epic scale chaos soace marine?
thanks for answering me also, its really hard to get measurements on this model.
EDIT. ok i have some epic scale chaos terminators, and i measured them in MM. i got this:
Epic Scale Terminator : 14 mm
40K scale Terminator : 56 mm
Epic Scale Plague Tower :
40k Scale Plague Tower (4 x Epic scale tower) :
PostPosted: Sun Aug 26, 2007 1:15 pm
14mm sounds a little tall to me.
Most Epic infantry are 6 to 8mm tall.
Mind you, 56mm also sounds tall for a 40k miniature. Most Space Marines are about 30mm to the eyes.
Are you including the height of the base?
PostPosted: Sun Aug 26, 2007 6:47 pm
Yes, 14mm is a bit high ... unless he used a Chaos Terminators, because of the spikes in top ?
PostPosted: Mon Aug 27, 2007 1:05 am
yeah, i used the chaos termies for my comparison. i messed up a lil on the measurements. used the wrong side of the tape measure. new measuremnet:
Epic Chaos Termie: 11mm
40K chaos Termie: 44mm
Epic Plague Tower: 50mm (5 cm as stated in response)
40k Plague Tower: 200mm (20cm)
so am i to assume that a 40k scale plague tower measures in at about 8 inches? that seems kind of weak. maybe i did my math wrong, can someone check my work to see if i missed something?
PostPosted: Mon Aug 27, 2007 9:16 am
Well you could also simply go by the official scale of the game: 1/300.
5cmx300=1500cm Then divide that back into 40k scale which is supposed to be something like 1/60 IIRC (I could be wrong here). which would put it at about 25 cm.
Personally I think something like 25-30 cm would be a good size in 40k. That would also make the whfb siege tower a good source for bitz.
PostPosted: Mon Aug 27, 2007 11:30 pm
Good point, WMN ! :D
Users browsing this forum: No registered users and 166 guests
