Post new topic Reply to topic  [ 153 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10, 11  Next
Watching Paint Dry 8: The Ocho - Wraithlord Time!
 Post subject: Re: Watching Paint Dry 8: The Ocho
PostPosted: Fri Jun 09, 2017 4:24 am
Stunning job!
PostPosted: Tue Jun 13, 2017 12:59 pm
Thanks Marko.
The Storm Serpents got their final two orange highlights last week along with some base touch up. They're now in the gloss and decal queue along with the Scorpions and Cobras.
The Void Spinners got their undersides take care of last night, I then glued them to their bases and started the black. I broke the turrets off to take care of their undersides, I need to clean up the mounting holes before I can glue them back on though. I wasn't a fan of the casting quality on the Night Spinner Arrays, so I'm coming up with a better option. That might take some time to resolve though. The good news is I think I can paint them separately and just glue them in later without too much fuss.
PostPosted: Tue Jun 13, 2017 1:12 pm
Also, I forgot to mention that Jav98/Nolo put together these for me last week:
https://www.shapeways.com/product/A7FDS ... forms-4pcs
I was after a more realisticly scaled HWP. You know, one that looked like it could fit through a Wave Serpent or Falcon door.
PostPosted: Thu Jul 06, 2017 1:44 pm
I meant to take these before our annual tournament but that didn't happen. Then I took the pictures and didn't post them for another week, so here we are! Work slowed on the Void Spinners so that I could base up my Falcon-hulled tanks, I managed to finish the black and do the cockpits and gems on the Spinners though.
These were my distraction, I did their undersides and glued them all to their bases. They're ready to paint at this point.
PostPosted: Thu Jul 06, 2017 2:22 pm
that's going to be some awesome panzer-elves!
PostPosted: Thu Jul 06, 2017 6:08 pm
im gonna repeat the word stunning, going to look amazing as an army
PostPosted: Fri Jul 14, 2017 1:16 pm
Thanks guys.
The Void Spinners had the last of their paint put down last night. I still need to get around to the gun barrel conversions, once they're all set painting those shouldn't take more than an hour or two. After that, they'll be in the varnish and decal queue with the rest of the super-heavies.
That means I'm on to the Falcon hulls, first up are the Firestorms. The engines on these are slightly more exposed so I might do an extra bit of highlight on them. Not sure yet, as I don't want to detract from the orange/blue/black. Thoughts?
PostPosted: Fri Jul 14, 2017 2:15 pm
engines look great, do em all like that!
PostPosted: Sat Jul 15, 2017 5:55 pm
Very sweet!
PostPosted: Fri Jul 21, 2017 1:12 pm
I was wondering why I was getting so much of a shadow on these as I was taking a picture. I realized afterwords that I only had one of my desk lamps on. Anyway, the Firestorms progress. The black is done, next week I hope to tackle the blue on the guns and maybe the gems. The recess lines are slightly less defined than the superheavies, so getting the highlights is slightly more difficult. That was compounded by the heat and lots fans that have been running in the local store where I paint this past week. The paint was drying on my brush before I got it to the model.
]Image
]Image
]Image
]Image
PostPosted: Fri Jul 21, 2017 2:24 pm
looking good Dave!
I'd suggest doing a brighter near-white highlight just on the outside edge of the black panels on those firestorms, make them pop where you can :)
PostPosted: Mon Aug 14, 2017 9:17 pm
Beautiful! They look fantastic in that scheme.
Emperors Children Log
Battle Reports Thread
PostPosted: Wed Aug 16, 2017 1:13 pm
Thanks guys.
I misplaced my camera for a bit but we're back. Not as much progress as I would have hoped in three weeks, but I've been working on some terrain for a new store in my area and also playing some Epic once a week too. Hopefully I'll have some pictures of the terrain soon. The gems and weapons are now finished up on the Firestorms. I also did the first highlight on the orange. Three more highlights and they'll be good for the clear coat queue.
I also started on this guy. The repositioning is set (striking his best Captain Morgan pose), I just need to go back and putty the joints I cut. The wings I'll put on after things are painted as it be too tight otherwise. Also, the weapons are magnetized using 1/16" diameter magnets.
PostPosted: Fri Aug 18, 2017 1:17 pm
I made two sets of eight hills for a local store, all they need at this point is some paint to help them match their tables (desert and grey wastes). They're made out of 1" insulation foam glued to tempered hardboard bases with some construction adhesive. I used a foam cutter to put some surface detail on their faces and covered everything with scenic dope (qt of latex paint, 2 latex caulk tubs and a cup of joint compound) for durability before pressing in the sand and spraying them with glue.
There's four bigger (18x12"-ish) and four smaller (12x6"-ish) pieces per set. They were cut out of 2x2' panels, I used the right angle corners so they join up easy and made them geomorphic. By that I mean the bigger pieces can be joined together and the same with the smaller. Also, the short edge on the bigger pieces match up with the longer edges on the smaller pieces. They can also be stacked, so there's lots of ways that you can put them together.
I was also able to cut six bases of scatter terrain per set out of the left over hardboard. No pics of those yet, I'll likely put a few rocks and some brush on them and make trees or something on smaller bases that can be moved around the area and not get in the way of the miniatures.
They were pretty cheap, price-wise. You can make four sets (32 hills, 24 scatter terrain pieces) for some $50, not including paint. They just take some time to put together.
PostPosted: Wed Aug 30, 2017 3:37 pm
I finished up the hills and a quick repaint of the desert and waste boards at my local store last Friday. The scatter terrain pieces got their base coats last night.
I also finished up the Firestorms, they got their last three orange highlights and their bases touched-up.
I was going to start in on my aircraft but I realized a painted army is within striking distance for Fall In, so I switched gears and got most of the way through my Farseer character upgrades. I need to add a highlight to the rune armor and bases, then highlight the black and do the gems. Any thoughts on what I should do for their topknots? Right now I'm leaning towards the same blue as their weapons.
Users browsing this forum: No registered users and 86 guests
