Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 1020 posts ]  Go to page Previous  1 ... 50, 51, 52, 53, 54, 55, 56 ... 68  Next
What are you working on? (vol VIII)
 Post subject: What are you working on? (vol VIII)
PostPosted: Mon Dec 19, 2005 6:00 pm
I've to transplant the hardware to the case of my old 486 (because it's not only looks better but is also easier to work with when exchanging parts).
Originally the machine had 16 megs of RAM (2x8). For DOS it might be allright, but for Windows 98 it's only the bare minimum. Lucky me, I had two further 8 MB sticks - again from my old 486 - so now it has 32. I've also used the PSU from my old PC, because the one this unit came with was a bit faulty.
My old HDD turned out to have a few badsectors - not enough to slap a "junk" label on it, but 2 badsectors are well enough to make me wary of using it for important data (about any data, that is). Fortunately the computer came with a 1 GB HDD, so I have something - remotely - reliable to set up Windows on.
All in all, I was done at 2:30 AM. ?
With basic assembly, that is. ?:(8:
I've found out that the motherboard has a built-in USB controller, just no slots - two of these plus an appropriate bracket are coming into the deal today.
I'm also hunting for another exchangeable HDD socket, so that I can use the 800 MB HDD for DOS.
t5h, why on earth would you want a DOS machine? ?That's a Linux firewall-to-be if I've ever seen one!
Linux-based firewall? ?Hmm... Might actually become another use for this thing, later on.
Now, why DOS? Well... is Doom 1 enough of an answer? ?:p
I like old DOS-based games, and using an emulator just isn't the same thing - plus some of the games run miserably.
Right now, I'm thinking of setting up the machine so that the Windows HDD is the Primary Slave, with the Primary Master being set to autodetect - the HDD socket being installed for it - and the Secondary IDE devoted to the 32x CD-ROM drive. The plan is that the PC normally runs with Windows - my mother will use it as a computerized typewriter of sorts - and inserting the DOS HDD into the socket before launching it will make the machine boot in DOS, thus enabling me to play various DOS games. ?:8):
Oh, and... that's how it looks:
I've put all the cabling so it takes as little space as possible - that's an old habit of mine, and rather a beneficial one.
I did very little in regards to modelling, unfortunately - but ?I've sorted up most of the sprues and organized the bits box way better then it was before.
Going to change the base of Chaplain Raziel - 40 mm will allow for suitably impressive look.
Planning a Sister of Battle conversion - at the moment, I've assembled a few concept photomontages in GIMP and in that regard it's shaping up nicely:
1 2 3
The upper half is from a Seraphim, the mace hand comes from an Ordo Hereticus Inquisitor and the legs belong to a Heavy Bolter Retributor. According to my predictions, the remaining parts will suffice for me to build a twin plasma pistol Seraphim Superior - something I've been thinking of for quite a while.
Also planning to paint up that Wardancer Lord I got a week ago, thinking of putting her in a duel diorama, probably against a Dark Elf or Daemonette.
The Fifth Horseman.
Quality over quantity.
PostPosted: Mon Dec 19, 2005 7:23 pm
The mace looks very fitting with a Sisters army.
PostPosted: Mon Dec 19, 2005 9:00 pm
TFH, you can run Doom of a modern OS, using compatibility mode and running it as if under another earlier OS. I run Doom 1 under my XP machine easily.
PostPosted: Mon Dec 19, 2005 9:08 pm
Hi guys,
I finally decided to scrap a pair of conversions for Chaos 40K I'd made years ago. They lived out several years in the display cabinet of a local store, and never ever took part in battle! Well, maybe the Landraider did once....
Remember this old beastie? on't worry, scrapping means removing some stuff and rebuilding it. This old glorious tank will re-emerge from the shops as a L&D Land Transporter  :D
Sorry for the poor pic!
Back from oblivion (again)?
PostPosted: Mon Dec 19, 2005 9:11 pm
I always liked the original 40k land raider, a very cool model!
This was a Khornate possessed Predator - on reflection, I did use it once (and I think it's Land Raider pal was there too - the front - er - thing was so wide that it couldn't get between a pair of buildings and had to move back and go a long way round to get where it wanted! :p
Anyway - it's already part-demolished, hence the unsightly white patches. This will be cleansed and given to a better owner - the Blood Axes!  :oops:
Astute readers will have notice that the LR in the previous pic had already lost its flimsily-attached lascannon.
PostPosted: Mon Dec 19, 2005 9:12 pm
Damn awseome predator!
PostPosted: Mon Dec 19, 2005 9:31 pm
pretty cool stuff Vanvlak.
PostPosted: Mon Dec 19, 2005 9:59 pm
So much nostalgia :D  Lovely stuff V :;):
Cheers! :)
PostPosted: Tue Dec 20, 2005 10:11 am
Hi all,
Not a lot of time to write, as 12 hour night-shifts are giving me little time to do anything but work and sleep, but I thought I'd drop in to see what's going on, and I'm glad to see you're all far busier than me on the painting front. :D
Now that I've refilled my EpiFunds with some very-welcome wages and have only a week left at work, I've planned my next Epic project for the new year (IG), bought the remaining pieces I need to round off both my SM and Ork armies, and am ready to start the major task of painting my BB pitch (oh, and find another job :P )
Also, in case I don't have time to post here nearer to chrimbo, I wish everyone all the best for the season, and hope you all have a great time. Cheers! :D
(a very tired) Duncan aka Freshmetal :D
Blastmarker.com
PostPosted: Tue Dec 20, 2005 10:16 am
Cheers freshmetal, and best wishes to you too! get some rest!
And I hope to experiment some new colour schemes on those two old 40K warhorses. :blues:
PostPosted: Tue Dec 20, 2005 11:25 am
Wow! So much ole skool goodness :8:
Great stuff :cool:
Nuf Said.
PostPosted: Tue Dec 20, 2005 1:00 pm
Great work all round Guys - Most impressive conversions & painting!
I finally delivered the WM Bretonnian commission last night...
Went a bit silly on the king's shield, so thought I'd post a pic to let you all know that the insanity hasnt left me, Im just not working on epic right now....  :p  :p   :80:
The whole army will be going on my site in Jan.
Paul "TuffSkull" T.
PostPosted: Tue Dec 20, 2005 1:02 pm
Whoa - nice work Tuffskull - this is one of my favourites fromyour portfolio. :D :D :D
PostPosted: Tue Dec 20, 2005 1:07 pm
D'oh...
I just realised looking at that photo I didnt highlight the tails on the last 3 character pieces for the army!!!
I hate it when I do things like that - get carried away concentrating on detail in one area and leave a glaring mistake somewhere else which lets the final piece down.. :angry: :angry:
Paul "TuffSkull" T.
Users browsing this forum: No registered users and 135 guests
