Post new topic Reply to topic  [ 151 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 11  Next
johnboyire's painting que
 Post subject: Re: johnboyire's painting que
PostPosted: Fri Feb 06, 2015 10:56 pm
kyussinchains wrote:
re: your guard list, I think you will really struggle with that build, you only have one fast formation (the Reg HQ) so grabbing objectives late in the game will be tough
with the rough riders, artillery batteries, sentinels and flak, you have 6 activations which are very vulnerable, 4 of them break as soon as they sustain a casualty....
you should really attach a hydra to every company you take, mostly to place the blast marker and prevent air assaulters gaining further advantage, but also to increase the ground flak you have, as you're not using planes either you are seriously lacking in air power, a marine air assault list would be thanking its lucky stars if it came up against that army
my suggestions would be to take at least another mechanised infantry company, that gives you two fast and robust formations to nab objectives with, drop the demolishers and add hydras to your companies, get rid of the shadowsword company and buy a pair of single tanks, if possible replace the basilisks with manticores, 9/10 times they are a better choice, and probably consider dropping down to two artillery batteries
I'd run with something like this:
RegHQ - Hydra
Mech inf -hydra
Tank Company - hydra
shadowsword
shadowsword
manticores
manticores
sentinels
rough riders
Thunderbolts
10 activations, respectable air cover with the planes, plenty of firepower and good engagement potential with the two mechanised infantry companies
optionally I'd swap the rough riders for a hydra battery to boost ground flak (people only make the mistake of letting rough riders survive once....) and potentially dropping a manticore battery to add-in deathstrikes if you're paranoid about titans and war engines making an appearance, use the sentinels to screen the artillery from teleporters, and try to be aggressive with the leman russes, make sure there is a commissar on the supreme commander stand (having a fearless supcom is worth the loss of a second leader in my experience) finally if you drop an artillery battery and the shadowswords, you can add in a pair of warhounds and second sentinel formation and you've got the all-conquering build used by Richard Laking to awesome effect over the last few years :)
im just after finishing having a look through my modest horde of epic stuff I was trying to get a mini guard army without buying more stuff, id like the list above it sounds good to me,
I may end up just ebaying the guard stuff as I was weighing them up v my squats and one army is going to have to go ive got way too much stuff with the admech army and the balance of a marine army to paint up
www.warheads.ie
PostPosted: Fri Feb 06, 2015 11:24 pm
primarch wrote:
To bad the Imperial Japanese army didn't field one of those at Guadalcanal.
:o
Don't you mean 'fortunately' instead of 'too bad'?
PostPosted: Fri Feb 06, 2015 11:35 pm
splash wrote:
:o
he had to pick the imperial side ;D
www.warheads.ie
PostPosted: Sat Feb 07, 2015 5:16 am
johnboyire wrote:
splash wrote:
:o
8)
PostPosted: Fri Mar 20, 2015 11:37 am
expanded death guard and legio mortis support
Added to the army to bring it to 3k.
x4 land raiders,
x1 hunter
x4 assault stands
x1 thunderhawk
x1 warhound
WIP:
ad mech army build up can start painting if my troublemaker stuff ever arrives...
long term projects:
pre-heresy world eaters 3k points army
pre-heresy emperors children 3k army
a few other 6mm projects.
trees and bases
ruins
purchased from fatfranks on ebay roads and rivers 6mm.
www.warheads.ie
PostPosted: Fri Mar 20, 2015 11:56 am
Looking great!
D.
PostPosted: Fri Mar 20, 2015 12:27 pm
Those roads and rivers are great, I'll have to look into those.
"I too shall be brought low by death, but until then let me win glory."
—Homer, Iliad, Book XVIII
The Unpronouncable Log!
PostPosted: Fri Mar 20, 2015 12:31 pm
he does 6mm 15mm and 28mm great prices too, http://stores.ebay.co.uk/fatfrankswargaming/
www.warheads.ie
PostPosted: Fri Mar 20, 2015 1:14 pm
Yeah fat franks stuff is great - I'm intending to get some roads from him but can't decide if they should be dirt roads or if I need tarmac looking ones if I'm doing a ruined city for Epic.
Did you cut those MDF square bases for the ruins yourself or did you buy them precut?
PostPosted: Fri Mar 20, 2015 1:20 pm
got them pre-cut
heres links to everything,
trees
http://www.ebay.ie/itm/310297103122?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
http://www.ebay.ie/itm/111023849948?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
tree bases
http://www.ebay.ie/itm/390926458290?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
bases for ruins
http://www.ebay.ie/itm/390926511612?var=660290854936&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
another batch i got, - too big for epic imo,
http://www.ebay.ie/itm/201165428499?var=500352851499&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
hills
http://www.ebay.ie/itm/261680242219?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
www.warheads.ie
PostPosted: Fri Mar 20, 2015 1:23 pm
ive got a good few pictures of the terrain in use here:
http://www.tacticalwargames.net/taccmd/viewtopic.php?f=4&t=27913&start=15
www.warheads.ie
PostPosted: Fri Mar 20, 2015 3:44 pm
Oh thanks for the links!
The smaller squares are perfect for the plastic Epic ruins.
PostPosted: Fri Mar 20, 2015 5:10 pm
I have looked at the FatFranks stuff on ebay several times. Whats it like in the flesh?
PostPosted: Fri Mar 20, 2015 6:50 pm
Cool!
PostPosted: Mon Mar 23, 2015 3:37 pm
got in some extra bookshelves to make room for the nerd display, epic armies and gothic fleet,
need to finish off my ACW 6mm then i can start on my Ad Mech army at last
www.warheads.ie
Users browsing this forum: No registered users and 91 guests
