Post new topic Reply to topic  [ 1935 posts ]  Go to page Previous  1 ... 43, 44, 45, 46, 47, 48, 49 ... 129  Next
Vaaish's random army painting log
 Post subject: Re: Vaaish's random army painting log
PostPosted: Thu Apr 28, 2011 6:01 am
Beautiful!!
PostPosted: Thu Apr 28, 2011 6:08 am
Great army.
PostPosted: Thu Apr 28, 2011 6:22 am
Brilliant work
looks like a studio army
PostPosted: Thu Apr 28, 2011 7:46 am
wow, simply awesome!
PostPosted: Thu Apr 28, 2011 12:38 pm
Wow. Fantastic work man.
PostPosted: Thu Apr 28, 2011 1:11 pm
Mate,
What does one say, that is an awesome looking army. Cant quite see the changes to hatch details. looking good.
Aaron
PostPosted: Thu Apr 28, 2011 2:08 pm
Thanks! I'll see if I can post a closer view of the changed hatches.
-Vaaish
PostPosted: Thu Apr 28, 2011 4:12 pm
Man that's a very pretty army!
PostPosted: Thu Apr 28, 2011 5:06 pm
How far away do you take photos from for army shots and single models? I guess you have a decent camera + light?
It varies. typically I'll shoot from about 6" away for a single model and focus to fill the viewfinder. For lighting, I use my regular studio lights that are on the painting table and a floor lamp as a fill light. I'l also use a sheet of white foam board as a reflector to bounce some of the light down on top to even things up. the end result are some fairly high res images that I archive for future reference.
-Vaaish
PostPosted: Thu Apr 28, 2011 7:56 pm
Excellent army, your pics never fail to impress!
My armies:
Imperial Guard: 5000+P
Necrons: 3000P
Space Marines: 3000P (WIP)
Tau: sometime eventually
PostPosted: Fri Apr 29, 2011 7:02 am
Here's the updated shot of the the macharius. I didn't have time to reshoot it so a zoomed in shot from the full army pic will have to do.
-Vaaish
PostPosted: Sat Apr 30, 2011 8:08 am
Fantastic looking army :)
I appreciate how you metallic turns out with a very matt finish looking.
PostPosted: Sat May 14, 2011 2:12 am
Vaaish wrote:
Same goes for the treads having pretty shallow detail making it hard to pick everything out.
Tread details need more relief, yes? A lot of the faces there are around .2 to .3mm, so I should take that into consideration when I make the loyalist Ellogram treads.
PostPosted: Sat May 14, 2011 2:28 am
I think it's the shrinkage from the metal casting that's the issue. The resin versions I used for the minorus were perfect and the treads turned out much cleaner than with the metals in the shots up there. If you compare the two you can easily make out the difference. Perhaps a slight exaggeration of details to account for the shrinking if metals are being considered would work.
-Vaaish
Users browsing this forum: Google [Bot] and 104 guests
