Post new topic Reply to topic  [ 242 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 17  Next
Strippers!!!!
 Post subject: Re: Strippers!!!!
PostPosted: Mon Nov 08, 2010 5:23 pm
Mephiston wrote:
Just don't try that with plastic PitFiend! This is where the multi-purpose of simple green shines through.
Ahhh... Ta. I'd not tried it on plastics yet.
PostPosted: Mon Nov 08, 2010 6:17 pm
Otterman wrote:
I'm still greatly disappointed that this thread isn't about real strippers.
I am so tempted here to start a discussion on male strippers. Possibly soaked in simple green/brake fluid.
PostPosted: Tue Nov 09, 2010 1:41 am
I could Link something Inappropriate if you would like? :D
PostPosted: Sat Dec 11, 2010 8:58 am
My recent experience with grease remover liquid
http://www.youtube.com/watch?v=BdPAFOWZhBU
Works like a charm
PostPosted: Sat Dec 11, 2010 10:51 am
Wow! What brand is that?
PostPosted: Sat Dec 11, 2010 11:40 am
Here it is called Ajax. (Belgium)
I also used Cillit but had the same result with the brandless, cheapest products too.
Ultra-de-greaser or something if I translate.
PostPosted: Sat Dec 11, 2010 11:46 am
Brilliant! - we used to get Ajax over here in the uk (my mum swears by it) but I think it's been rebranded
BTW was anybody else absolutely desperate for there to be another pair of tweasers holding the model down in that video, just me crazy?
PostPosted: Sat Dec 11, 2010 11:56 am
The other hand was holding the camera...
;D
PostPosted: Sat Dec 11, 2010 12:50 pm
Same here.
I was torn by the horrible dilemma : reality told me that he had to hold the camera, but my inner self didn't want to listen.
PostPosted: Sun Jan 30, 2011 2:30 pm
Not sure if this ones been covered, but MR MUSCLE FOAM oven cleaner works a treat on metal minatures! Gloves are advised as this is nasty stuff and will burn you, I did some 28mm minis in about 40mins,and a tooth brush only METAL for this product i think though.
Regards epic
PostPosted: Sun Jan 30, 2011 4:54 pm
I guess Easy Off oven cleaner might work as well.
PostPosted: Sun Jan 30, 2011 6:09 pm
I think any foam oven cleaner would work, the more warning signs on the can the better the job it does ;D
Have also heard surgical alcohol works at stripping minis awell, but not tried that,
Regards epic
PostPosted: Sun Jan 30, 2011 8:09 pm
I've had one slightly odd experience on an older 28mm figure with Mr muscle oven foam cleaner, I'm not sure if I left it on a little long but it left a marble like patina across the whole model which wouldn't come off.
BTW it cleans up paving stones a treat!
PostPosted: Sun Jan 30, 2011 9:08 pm
Yes may of left it two long, I just put five 28mm figs in an old pint glass and srayed the foam in, Jingled it about a bit and sprayed a bit more foam in, left for 20 to 25 mins then tipped out and rinsed off, then scrubbed! Then did another session to get rid of the remaining paint.
I have read on the internet that some very old lead figures can turn strange due to lead rot etc when stripping, Im going to try some acetone in a few days its supposed to be awesome but the fumes stink. But will definatly use mr muscle again.
Regards epic
PostPosted: Sun Jan 30, 2011 11:07 pm
yeah, I meant to type "old lead 28mm figure"
Acetone is ok, I use powerspray as my first choice and acetone mostly just for loosening superglue
Users browsing this forum: No registered users and 241 guests
