Post new topic Reply to topic  [ 1173 posts ]  Go to page Previous  1 ... 34, 35, 36, 37, 38, 39, 40 ... 79  Next
Apoc's epic projects
 Post subject: Re: Apoc's epic projects
PostPosted: Sun May 11, 2014 9:15 pm
kyussinchains wrote:
primarch wrote:
Sweet idea. Now I can finally have a retarded 3 power fist reaver titan and live out my Pacific Rim fantasies! ;D
I enjoyed Pacific Rim as well, and that three armed battle robot would make a mean close combat warlord. ;D
I think you'll find that would go against L4's battle doctrine.....
Being the one with lime colored thunderbolts, I think I can mange his wrath. ;) ;D
PostPosted: Sun May 11, 2014 9:32 pm
Personally I agree with L4 on the titan front in terms of theory. Titans should be large gun platforms, land battleship style.
Or, they can be used for siege assault roles – close range weapons and wrecking gear is fine here as static fortifications are too slow to run away from a titan and may require the 'next level' of weapon to breach in order to avoid stand offs.
However, when it comes to playing EA in anything other than a narrative/themed battle i'm right in with CCWs and short/mid range weapons on titans :D
PostPosted: Sun May 11, 2014 10:08 pm
C…come at me bro!
YES! :spin
PostPosted: Mon May 12, 2014 3:54 pm
C…come at me bro!
I'm going to aim to get my mk3 done next weekend. Although at present I have no idea where the head is …
but here are the legs wip at least:
What magnets are you guys using?
Mostly a mix of 2 and 3mm diameter rare earth magnets (mine are from 'modifix' brand). 4.75mm magnets for the warlord waist. Holds mk3 weapons fine, not tried mk1 corvus yet.
Violates everything in the L4SoTR :tut :gah ... just shoot'm before you put him on the board ... >:D unless you're going run him around to draw fire ... ::) :P ;) 8)
PostPosted: Mon May 12, 2014 3:59 pm
And the now blind shall see !!!!! :o ::) Very good assessment kyussin ... ;) :D ;D
PostPosted: Mon May 12, 2014 4:06 pm
Wait, L4, you don't understand! That's a flack-titan, very practical. I agree it can't hope to catch up with and assault tank companies on land. It uses the CCWs to defend against air assaults, just jumps up and swats thunderhawks out of the sky!
PostPosted: Mon May 12, 2014 4:07 pm
Well at least you got the theory ... ;) My preaching has not all been invain ! :o Or you were tactically savvy enough to see the paradigm ... :D ;D Of course the way we play Epic ... if you show up on the board with any CCWs ... you'll die in an inferno of explosions and fire ... >:D <MWWWAAHAHA !!!!> :whistle ^-^
PostPosted: Mon May 12, 2014 4:10 pm
What scares me is some may actually believe that !!!! :o :{[] Must be a tactic in the King Kong School of Anti-Aircraft techniques ... :o :nooo
PostPosted: Mon May 12, 2014 4:46 pm
Legion 4 wrote:
:o :nooo
Here you go L4, i kitted the mk2 out with the biggest guns I had. Looks a bit top heavy but should help you sleep easier :D
hmm not biggest actually, i have a deathstrike head somewhere … seems i need to magnetise even more things! will stick to painting a bit here and there for now though, magnetising is more time and space intensive!
PostPosted: Mon May 12, 2014 5:09 pm
Bah, in AT the easiest method to kill another titan was with close combat weapons.
I'll take the 3 armed titan doing the "typhoon attack pattern" in those cases. ;)
PostPosted: Mon May 12, 2014 8:03 pm
Very, very nice work on that big gun pack'n heavy metal beast !!!!! Now that's a Heavy Combat Walker !!!!! :spin I feel much better now ... ;D
PostPosted: Mon May 12, 2014 8:07 pm
Not after a few games with me ;D ... they learned ... :gah .... The hard way ... they'd never get close enough to use CCWs ... >:D "Burn Baby Burn ! " Was often heard from my side of the board ... ;D My big badd Warlord would be glad to fight along your Bad Boy, Apoc ... ;D Image
PostPosted: Mon May 12, 2014 8:30 pm
Well depends on the ruleset used. I'd take your bet under net epic or AT quite easily. ;)
PostPosted: Mon May 12, 2014 11:30 pm
Indeed ... ^-^
PostPosted: Tue May 27, 2014 8:27 pm
Apoc, do you still need ogryns? Will you be at expo?
Users browsing this forum: Google [Bot] and 90 guests
