Of the 4 Astartes Chapters to present themselves at Warzone Palavan, the Raptors 'legion' was by far the force most likely to work directly with contingents of the larger Imperial Crusade armies. Scions of Corax, they were unsurpassed in their abilities for deep scouting and rapid ranging far beyond even the the rest of the marine forces present. Typical of their battle doctrines, numerous Scouting element would independently disperse into difficult terrain regions seeking for for signs of the enemy. A favorite vehicle of these forces was the specialized variant of the Land Speeder, the Storm. Forgoing heavier armaments, it allowed the vehicle to carry a full 5 man squad. In addition, the presence of baffled engines and a sophisticated spy array, allowing for stealthy insertions behind enemy lines such as shown in this recon flight deep into the almost impassible Matarak wastelands to track the traitor forces without their knowledge.Attachment:
painters notes:
Some cute little scout speeders to add to the collection. While they don't actually have a list to work in as is, they will count-as Land Speeders just fine. Similar to my guard, I didn't want just a uniform force in the collection and because I intend a large scout contingent, I decided to go with the Raptors who are known for their stealth and scouting tactics. As simple army green men flying in army green vehicles would be a bit boring visually, I decided to move away from strict fluff to paint the scouts in AP Uniform grey base on their uniforms and then highlights of Astornomicon grey. The occasional place where you can make out a boot then got the GW Snakebite Leather tratment. The chassis was base coated in VMA Intermediate Blue. Both the shoulder pads and the upper part of the vehicle panels were then painted in VCG Caiman Green. A layer of GW Gretchin green was then blended in. Finally a sharp edge highlight of GW Camo Green was added to make it pop. The underside was actually left in the grey base and due to the wearing action from my fingers, had actually a really nice bit of wear and tear that I left as is. While you can't see it typically, up close straight on, you can see the used look. Note shown, but the tri-thrusters were picked out in some GW scab red=> sunshine yellow blends for the engine. Again to help break things up a bit, I moved away even more from the fluff and gave a few of them a dingy white helmet which I plan to echo on some of the recon squads on the ground to tie the force together visually. The basing was area in sculpted Vallejo Snady Paste and then some bits of GW Agrellan Earth to give the drying waterway/mud look.
edit: the plinths were made from Everbilt #18 5/8" wire nails. I drilled a 1mm hole through the base, pushed them through from the bottom as a tight fit, clipped the head off flush, and then mounted as various heights and rolls. very cheap (1.50USD) and quick to do.
I HAVE NO POINT-
Penal Legion-Fan list-
Help me make Whitescars not suck!
