Post new topic Reply to topic  [ 515 posts ]  Go to page Previous  1 ... 21, 22, 23, 24, 25, 26, 27 ... 35  Next
Petit crabe de fer en colere
 Post subject: Petit crabe de fer en colère
PostPosted: Wed Mar 18, 2009 10:09 pm
I agree. I think you could make the barrels bigger and have them touch without it looking odd at all.
PostPosted: Wed Mar 18, 2009 10:40 pm
energy /coolant cables?
My shifting projects
PostPosted: Wed Mar 18, 2009 11:44 pm
An interconnect should be fine, as it can always be snipped off the end product by a careful converter.
PostPosted: Thu Mar 19, 2009 12:04 am
Stunning work!! :oo:
Im new in the forum, and looking for some good ideas for my new chaos army, i find this!
Incredible.Good luck with the moulds, me and my spanish friends need some... :wow:
PostPosted: Thu Mar 19, 2009 6:06 pm
Quote: (BlackLegion @ 18 Mar. 2009, 19:08 )
Wellthe two barrels doens't have to be separate. An indentation (= two tubes adjacent to each other so that they touch each other) would suffice at this scale :)
I gotta agree :;):
Coffeeeeeeeeee...........
PostPosted: Thu Mar 19, 2009 8:10 pm
Thanks, guys. I sent the picture to Todd Boyce to see if he has any opinions.
PostPosted: Thu Mar 19, 2009 8:22 pm
what's the diameter of one of those barrels on that autocannon?
PostPosted: Thu Mar 19, 2009 8:40 pm
About 1.25 mm
PostPosted: Fri Mar 20, 2009 7:57 pm
Quote: (Otterman @ 01 Mar. 2009, 18:26 )
Heya Vermis, the process is called investment casting. The output of Todd Boyce's machine is a delicate kind of plastic. To make a vulcanizable / sturdier pattern, he dunks the plastic original in enamel with some extra feed channels.
I originally thought the output of the machine was a kind of plastic but I'm now pretty sure the material is a very hard wax - similar (if not the same) as jeweler's wax.
I deliver the part to the investment caster where he attaches a wax sprue (you can see the attachment point on the autocannon). It is then suspended by that sprue in a molding compound slurry (within a thick metal flask) about the consistency of buttermilk. That then hardens into a rigid mold around the part with the sprue sticking out the top.
The whole thing is then stuck into a kiln and heated to a thousand-plus degrees until the wax model and the sprue are vaporized and burned out of the mold, leaving an empty cavity. Metal is then poured into this mold through the hole the sprue left behind (I think this pouring happens within a vacuum chamber but I'm not positive) and cooled.
The flask is pounded on with a hammer which shatters the mold material inside (which basically breaks apart like a very fine sand packed tightly) and the part is extracted and cleaned of any remnants.
If all goes well, you have a more valuable metal copy than the original wax copy - which is why it's called an investment cast. And like all investments, there is a chance that it won't pay out in the end.
Todd
PostPosted: Fri Mar 20, 2009 9:24 pm
"Lost Wax" casting is pretty cool. The metal is probably added via spinning into the mold. No vacuum needed. I did that in jewelry making class in college. We removed the mold once it was spun by dumping the whole thing in water, which dissolved it quickly. There are probably other ways to do this type of thing though.
PostPosted: Mon Mar 23, 2009 10:16 pm
It's been a while since I've been on TacComms but this thread keeps dragging me back and while it looks like the Otter is getting plenty of encouragement but here's some more: GO GO GO OTTERMAN, that robot crab is looking superb. :agree:  :agree:
PostPosted: Mon Mar 23, 2009 10:43 pm
And here's some encouragement for you: Todd mailed all of the bronzes to me, sans autocannon. They will probably arrive Thursday or Friday.
PostPosted: Mon Mar 23, 2009 11:23 pm
Oooh! *drumroll!*
MoK's Painting Blog
Now Showing:
PostPosted: Thu Mar 26, 2009 2:14 am
The bronzes arrived today. Here are the pictures, compared to a tankette, an angry robot bug, and one of Illuvitar's design.
The autocannons are casts from the PrintAPart job.
As you can see, the 4:1 error has resulted in a petite crabe that's not so petite.
PostPosted: Thu Mar 26, 2009 2:25 am
Great!!! I want 10... at least :D
Users browsing this forum: No registered users and 204 guests
