Post new topic Reply to topic  [ 80 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
AMTL, AdMech, Eldar Titans and Chaos... eventually.
 Post subject: Re: AMTL, AdMech, Eldar Titans and Chaos... eventually.
PostPosted: Sun Oct 04, 2015 1:52 am
Nice work on the renegades, looking forward to the completed forces.
Agree with you on always having a constant flow of epic goodness minatures always flowing in ;)
PostPosted: Sun Oct 04, 2015 1:48 pm
Ooh they look like cousins of the Alpha Legion...
PostPosted: Sun Oct 04, 2015 4:12 pm
Lovely titans indeed.
PostPosted: Sun Oct 04, 2015 10:08 pm
Thanks guys. They do look a little like Alpha Legion, yeah... the bone helmets help them pop a little more, whilst the overall scheme isn't overly bright.
Managed to finish up 3 more stands, a Predator and a Rhino. Here's the tanks -
The host (hmm, that name kinda works... 'The Host') so far -
Stuff lined up on the painting table, aside from titans, is a pair more stands, a pair of Noise Marine stands, 3 more Preds and 3 Vindis and the sheer joy of a Thunder thunder thunder.. Thunderhawk!
I also have a bunch of other flyers to paint up, so I'm somewhat inundated for choice currently. Thanks to the Imperator conversion finding a new home I've also ordered the parts for the next bigger project, so that's going to be fun once it arrives sometime midway through next week!
PostPosted: Sun Oct 04, 2015 10:10 pm
nice!!
I'd recomend to do some lights on the gold with silver or something like that :P
but they look really cool as they are! :)
PostPosted: Mon Oct 05, 2015 12:10 am
Cool!
PostPosted: Mon Oct 05, 2015 11:22 am
Looking good.
PostPosted: Mon Oct 05, 2015 12:36 pm
That's an interesting base color you got there
PostPosted: Tue Oct 06, 2015 9:08 am
Nice job on the chaos marines, Thunderhawks are awesome ! need to get some more for myself ;)
Good luck on the new project looking forward to it.
Also looking at your stands what grass are using it looks great ?
PostPosted: Tue Oct 06, 2015 11:01 pm
Cheers!
I probably should highlight the gold again - I actually got a paint to do just that and used it a bit, but not on everything. Maybe when I get back round to the titans.
The base colour is just Tamiya Dark Green, and I mix in GW's Sotek Green to highlight it.
The grass is just a mix of 'soil', 'dark green' and two types of 'light green' from Woodland Scenics - clump foliage for putting on trees. Since it's pretty small it works fairly nicely.
Managed to finish up the (currently) remaining 3 Predators and 3 Vindicators, so I have a full armoured detachment painted now with some upgrades. I actually have points now! I figured I'd show them on the base for the big project that'll be coming soon...
PostPosted: Sun Oct 11, 2015 2:14 am
The dreaded double post!
I've not been idle the last few days, oh no. I mentioned that a big project was coming and since most of the parts arrived that's what I've been working on. To start, a few pictures to explain where I'm going -
This shows the Warlord in a scale shot with the Reaver, and shows it's similarities to the Imperial Knight model GW does.
Similar legs, shoulders, chest armour, hips, overall torso and so forth.
I then used this image to judge relative scale -
With the true scale titans floating around, this image seems pretty spot on. Dividing the approximate 28/30mm scale height by 5 to get to Epic dimensions, the Warhound comes out at 1.96" tall and the Reaver at 3.15" tall. This is almost spot on to what the figures actually measure as, give or take a small fraction on an inch. As such I figured the pictured silhouettes were likely to be a good guide, especially with the previous Warlord scale shot. This would put a Warlord at about 4.72" tall.
The GW Imperial Knight however is approx 6" and a bit tall - too big for a Warlord. The Imperator however comes out to 7.08" tall, and once you add on a bunker and some towers...
This fellow comes out to 8" tall overall, thanks to the two chapel-like towers on the top of the bunker. It's close enough for me though, since he looks like an imposing God-like engine of war! The true scale Reaver and Rhino gives a sense of just how massive this guy is, and I'm extremely proud of him!
As you can see he's not quite finished in terms of parts - I'm waiting on a bits order with the two remaining shin guards to construct the remaining leg armour and a Leman Russ plasma cannon is also on the way to make the Annihilator to go on the unfinished arm. There's a bit more smoothing out to do on the join between bunker and carapace, but it's largely finished on that front.
Both arms and the torso are currently unglued to make the big guy easier to paint. It's pretty hard to see in the shot thanks to it all being just primed, but the base does have ruins and Skitarii marching between the legs, since he can transport them. There's a furrow at the back of the base to put a crashed flyer on the base too once that arrives.
With any luck I'll make some good progress on the lower half of this guy in the next few days and I'm really looking forward to seeing this monster coming together!
PostPosted: Sun Oct 11, 2015 5:12 am
And now sir, you have my attention. :)
PostPosted: Sun Oct 11, 2015 6:13 am
Wow!
PostPosted: Sun Oct 11, 2015 6:57 am
Nice work on the imperator sir and clever use of the dystopia wars fortress for this I never would have thought of that. You are not the first to use the knight model as a true scale imperator as another guy here actually did some 3D designed and printed parts that would fit into the recesses on this plastic kit, can't remember who it was now though. But your idea looks great I must say so consider the idea stolen for my own conversion once i get going on it that is.
Once again great work and i look forward to seeing the finished item.
PostPosted: Sun Oct 11, 2015 10:50 am
wow man!
just awesome stuff!!!
