Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3, 4  Next
6mm 40K, 6mm WFB, 6mm LOTR , 6mm HC and everything 6mm
 Post subject: Re: 6mm 40K, 6mm WFB, 6mm LOTR and everything 6mm
PostPosted: Sat Aug 31, 2013 11:04 pm
Eldar are not an easy army at an Epic tourney! must try harder. i used 20mm by 40mm magnet sheet sprayed grass green, with the old square base flag poles stuck to the back edge. i used the 3 minimum figs per base.
File comment: funny 20 min void spinner proxy made form a Tempest hull and 3 Doom Weaver turrets pushed into splodge of Miliput.
File comment: Shinning Spears and Exarch, cut underslung Shuriken Cannons off, will model twin Shuriken catapults
File comment: Biel-Tan scouts
6mm40K + viewtopic.php?f=7&t=24667
PostPosted: Sun Sep 01, 2013 1:07 am
Nice work ! 8)
PostPosted: Sun Sep 01, 2013 7:28 pm
These are absolutely brilliant
Rightyus Indergestyun I
Stabb-Blasta II
Verum Irae II
PostPosted: Wed Sep 11, 2013 9:40 pm
thanks guys :)
FINALLY finished the Ravenwng Squadron.
Dark Talon
Nephilim Jetfighter with twin Lascannon
2 off Nephilim Jetfighters with Avenger Mega Bolters
PostPosted: Wed Sep 11, 2013 9:48 pm
nearly finished the Land Speeder Vengence. any more i make will be smaller. difficult to use WD as the basis, should have googled for different angles, its very large and flat!
Assult Cannon cut form Contemplator Dread, going to give him something more dramatic...
next Sammael, Black Knight Bikers, Darkshroud and Deathwing Knights
PostPosted: Mon Sep 16, 2013 3:07 pm
Great work! The Nephilims are awesome!
Have a look here! https://sites.google.com/site/pocketw40k/
PostPosted: Mon Sep 16, 2013 4:23 pm
Thanks for info Levian.
i havn't tried 6mm40K in converted scales yet (the excellent Pocket 40K), from memory an infantry fig moves 1.2 inches or 3cm, and fires 12cm. in our 1 inch to 1 cm your infantry fig moves 6cm and fires 24cm.
so you have a choice. recreate 40k in small scale on very small tables, with very small weapons ranges. which is fine. bearing in mind that the figures are not to scale anyway, ie a Rhino is not to scale with epic space amrines.
or, play a slightly different game with more rapid movement and interesting weapons ranges, with 40K characteristics and special rules. with no scaling.
jury is out
PostPosted: Wed Sep 18, 2013 7:44 pm
Lovely scratchbuilds again.
Stabb-Blasta II
Verum Irae II
PostPosted: Fri Jul 25, 2014 9:04 am
My 6mm40k projects have been on hold, i've been bitten by a Warmaster fantasy bug! typical to get into a figure line when it is oop!
6mm centurian scratchbuild
PostPosted: Fri Jul 25, 2014 9:10 am
from the side
PostPosted: Fri Jul 25, 2014 9:15 am
from the rear
method. i cut the hell out of a 2nd ed space marine, to get the right helmet and dimentions. build feet
and placed the fella on the feet. then built up the armour around him. added electrical ferrels for guns and plasticard for armour plating. he should have thums, and rocket launchers on his chest. when painted i hope the hard work will show!
he isn't based the same as the adjacent marines yet, being perhaps 1mm too short at the moment.
PostPosted: Wed Jul 19, 2017 11:50 pm
I really like that stegadon from your first post, what is it? scratchbuild or from somewhere? do you have any process pics on that? and where are the lizardmen from.
great work on everything else as well :)
My FB page dealing with 6/8mm and other modeling topics
https://www.facebook.com/groups/1682441262062813/
My Gumroad page
https://gumroad.com/wakesemporium
My Shapeways Shop
https://www.shapeways.com/shops/wakes-emporium
PostPosted: Wed Feb 21, 2018 9:45 pm
hi Wakelessrex, the stegadon is a Styrcacosaurus from the 10mm Magister Militum dino range. from memory the lizard men are heroics and ross Egyptians, with javelins and loin cloths, with tails and crests added in greens stuff, shields are green stuff, poles are thin wire (resister legs from work)
sorry for late reply.
i have a load of new figs to post pics of, so i should get on with that! 8th ed 40k plays really well in 6mm :0)
i've got people at work playing it!
PostPosted: Fri Feb 23, 2018 3:04 pm
a few pics, some unfinished.
Users browsing this forum: No registered users and 152 guests
