Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 43 posts ]  Go to page Previous  1, 2, 3
Stripping Paint
 Post subject: Stripping Paint
PostPosted: Fri Nov 21, 2003 2:32 pm
About ?3.50 for a tin of nitromors and I did a 93 model IG army for 40k with it.
Although nitromors is dangerous, and you should do it outside with old clothes and rubber gloves on, from what I've seen you will be a lot worse off if you make a mistake with brake fluid!  then again, if brake fluid works on plastics...
If you love something, let if go.
If it doesn't come back to you, hunt it down and kill it.
PostPosted: Fri Nov 21, 2003 4:43 pm
For me, Nail Polish Remover for metal and Simple Green for plastic, and those work most of the time ...    :;):
PostPosted: Tue Dec 02, 2003 12:39 pm
well, I have to say, an excellent response   :p
the best thing for Metal IS nail varnish remover, sock the figure in it, go to pub, return to have it slipping off the model.
Excellent.
"Thou shalt not suffer the Xenos to live!"
PostPosted: Tue Dec 02, 2003 4:41 pm
That'll work ... :laugh:
PostPosted: Tue Dec 02, 2003 5:53 pm
Nail Varnish remover used to have Acetone as an ingrediant.  Another solvent which I have access to, due to where I work.  Trouble is it evaporates very quickly.
PostPosted: Tue Dec 02, 2003 7:08 pm
..Yeah, I was just going to post this- I used it a few months back to strip some Imperial Knights, and nearly overnight all I used had gone...  :oo
www.darkrealmminiatures.com
PostPosted: Wed Dec 03, 2003 5:57 am
Ah ... guys ... try covering the container with plastic wrap or use a jar with a lid to soak your models ... ???
PostPosted: Wed Dec 03, 2003 2:04 pm
Lol.. I have to say I did realise this might have helped... but only after it had all gone!  :laugh:  :blush:
PostPosted: Wed Dec 03, 2003 4:02 pm
"Learn thru doing" ... :D  I'll be 47 in a few weeks, and I'm still learning ! :blush:  :laugh:
PostPosted: Wed Dec 03, 2003 11:38 pm
I used nail polish remover to get off paint once, I can't say I was terribly impressed with the result, but then against the coats on the miniature where real thick.
PostPosted: Thu Dec 04, 2003 1:30 am
Soak it & scrub with old tooth ... repeat as needed ...
PostPosted: Thu Mar 11, 2004 11:13 am
Brake fluid works well but keep an eye on it when stripping plastics.  A couple of hours on metals the clean them up with a light soapy wash. :oo
Knowledge is power. Seek it out.
PostPosted: Tue Apr 06, 2004 3:45 pm
This topic has been archived!
