Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
All this CAD malarky
 Post subject: All this CAD malarky
PostPosted: Fri Sep 25, 2009 1:08 pm
Glyn, do you mean 6mm scale shoulder pads? Those would be too small, IMHO.
PostPosted: Fri Sep 25, 2009 2:12 pm
I don't see 6mm shoulder pads printing well, especially with detail on them. That's just too small a scale for printing, and definately too small for metal casting.
PostPosted: Fri Sep 25, 2009 3:04 pm
Can you model stuff up for this process in 3Dsmax?  If so, what file format must the model be in for printing?  I work with 3Dsmax everyday, but thats about it when it comes to my knowledge of 3D packages.
PostPosted: Fri Sep 25, 2009 3:10 pm
Yes you can.
The export format is .STL
PostPosted: Fri Sep 25, 2009 3:13 pm
Ah cool - whats the rules on intersecting geometry?  Does it have to be clean as a whistle - ie: all verts welded - no overlapping on faces, or is it pretty forgiving?
PostPosted: Fri Sep 25, 2009 3:19 pm
100% clean.
PostPosted: Fri Sep 25, 2009 3:25 pm
cool, thanks.
PostPosted: Fri Sep 25, 2009 3:41 pm
6mm marine shoulder pads was the slightly crazy idea, yes. The resolution of the detail on some of Omans models looks somewhat smaller and more delicate than a shoulder pad so I was thinking it might come out ok, though at the very limit of what could be done.
Obviously a single shoulder pad would be too small to cast on it's own but I was imaging casting a number of them on a supporting sprue that they'd need to be cut off from (the interior of the shoulder pad would also be solid and not hollow as the W40k ones are, but they could be used like that or hollowed out before use if need be).
PostPosted: Fri Sep 25, 2009 6:00 pm
Glyn: Pieces that small are difficult to cast in resin, let alone metal. Even if you could somehow get them printed at a good enough detail (unlikely, since the best you'll really get is 0.2mm accuracy), you'd never be able to cast them.
You'd have to model whole marines to have any chance really.
PostPosted: Mon Nov 23, 2009 4:31 pm
I downloaded a Moment of Inspiration last night and had a very quick play. I've never used a modelling package before and have no idea what I'm doing so it'll be a steep learning curve till I (hopefully) work out what I'm doing and maybe (touch wood) produce something good.
Quick question: how does scale translation work? Say I measure a real something that is X mm long on one dimension, how long would I need to make that on screen?
Are there guides anywhere on the net how to go about using MoI for this sort of thing? Or should I just have a good read through of the help files and have a go?
PostPosted: Mon Nov 23, 2009 4:59 pm
Heya Glyn, you can set the dimensions thusly:
Click the Options button (lower lefthand corner, looks like a cog).
Select the 'General' tab.
Find the drop-down combo box at the top that says "Unit system:", select millimeters.
I'll dig up your email later and zap you a file or two.
