The primary worth of Patsayev IV was the infrastructure and expertise in volatile, rare, and complex chemical manufacturing and production of fuels from it's large natural reserves. Of importance was the safe recapture of the vast fields of chemical tanks surrounding the spaceports. After the cult uprisings that drove the worlds of the Calliandra cluster from Imperial control, the fields were abandoned and left to deteriorate despite their obvious material wealth.Attachment:
Of tactical difficulty was the fact that high intensity mechanized forces would inevitably cause unacceptable levels of collateral damage to the facilities (as well as being a huge danger to both the traitors and the imperials due to the risk of uncontrollable conflagration). Therefore it fell the 999th Penal Legion to perform wave attacks without regards to casualties until the facilities were recaptured or they were destroyed in the process.Attachment:
painters notes:Some more great products from Wasteland. I knew I wanted an very bright gaudy color to the tanks so I went with AP Demonic Yellow sprayed over a base of VAC Khaki tan. Then I went to do an mid-shading pass with the airbrush along the edges with a brown wash using it as a localized filter of sorts (one of my airbrush tricks).
Wanting to use up the last of the bottle of GW Devlan Mud I decided to use that. BIG MISTAKE. GW products of that era simply do not have the pigment to play nicely with anythign airbrush related. Tons of overspray and clogging mucking things up terribly. The pigments too thing to stick where you put it say unlike AP or Valejo washes. At least I figured that it'll just require a little extra attention with the 2nd pass of yellow color to settle that out on the flat areas. No biggie, right? Well as I kept trying to give a color pass that it kept randomly giving me green and brown tones all over from the pigment in the yellow interacting with the devlan mud underneat!!!
It was REALLLLLLLY terrible looking. Not wanting to dump the whole thing in stripper I decided to see what I could do to make those off the wall reactions work for me instead and I thought of terribly caustic chemicals and Batman-esque acme chemical plant vats and went for it. First was to go work on it with repeated uneven applications of Woodland Scenics Burnt Umber washes to break up the overspray and work as a discoloration. Then it was time to start streaking with various art store burnt sienna and prussian blue, mig productions olive green, starship filth, un white, etc. Throw on extensive chipping (chardon granite with a second pass of gunmetal). Rust it up with mig old rust and you kinda get something that kinda works in the end.
I HAVE NO POINT-
Penal Legion-Fan list-
Help me make Whitescars not suck!
