Post new topic Reply to topic  [ 242 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 17  Next
Strippers!!!!
 Post subject: Re: Strippers!!!!
PostPosted: Thu Sep 11, 2014 3:59 am
DK, those bikes metal? You can go the nuclear option with them and dump them un acetone or other industrial solvents then
PostPosted: Thu Sep 11, 2014 6:48 am
Acetone +1
PostPosted: Thu Sep 11, 2014 10:55 am
yeah nail polish remover is quick and effective and all you have to do is stink out your entire house when you use it....
PostPosted: Thu Sep 11, 2014 10:59 am
Outside. That shit'll eat your brainz too ..
Let there be code.
PostPosted: Thu Sep 11, 2014 12:18 pm
Isn't nail polish remover usually watered-down or otherwise mixed with other things. It's quite an expensive way to buy acetone, too. Just go to the chemist and ask for a bottle of acetone, but be prepared to be interrogated as to exactly what you need it for (not only is it toxic, but it's also a key ingredient in a highly unstable explosive).
- George Borrow
PostPosted: Thu Sep 11, 2014 12:28 pm
I just get the cheapest nail polish remover I can find... usually less than a quid
fairy power spray is the expensive stuff, £3 for about 350ml
PostPosted: Thu Sep 11, 2014 12:32 pm
Alas no, only plastic bikes. They're going in for another bath - I have a lot of old Ultramarines in that blue so I'll have to find a good way to exterminate them all without an ordinatus solution.
Oh, and I get my nail polish remover with a strawberry scent. It's never done me any rhubarb.
PostPosted: Thu Sep 11, 2014 12:49 pm
Nail polish remover/acetone will murder plastics.
I still recommend denaturated alcohol. 92% pure is what I use.
Let there be code.
PostPosted: Thu Sep 11, 2014 2:31 pm
I have been told that for really stubborn paint, try acetone-free nail polish remover....
but DO NOT SOAK THE MODEL!! a few seconds in and out, followed by a quick scrub should be enough
I found out that even without acetone the stuff EATS models if you leave them in for more than a few minutes
*DISCLAIMER*
I make no promises of either acceptable paint removal or model safety... just passing on what I've been told....
PostPosted: Thu Sep 11, 2014 3:41 pm
Bezerkmonkey dropped his into a sonic cleaner deal and evidently it rocked crotches (his blog has the details)
PostPosted: Thu Sep 11, 2014 4:01 pm
yeah I've used a sonic cleaner on FW resin and it worked quite well (it also vibrated all the component bits apart which was a convenient, if unexpected, bonus)
PostPosted: Thu Sep 11, 2014 5:02 pm
Acetone for metal is a winner. It costs 8£ or so 500ml ( well in Finland) and you get it from stores that sell house paints, hardware stores. Break fluid for plastics is awesome. Those are what I use and ofc brush the minis after the bath. Break fluid is cheap. Both are toxic so handle them carefully.
PostPosted: Thu Sep 11, 2014 5:03 pm
I'll take a look for the sonic vibrator thing, thanks! Any thoughts on makes/models that come recommended, or are they all much of a muchness?
PostPosted: Thu Oct 30, 2014 1:48 am
been reading up on stuff called Dettol. it's a antiseptic. I have been using Simple Green with good results but it isn't quick and doesn't work on some paints.
I will update later with the results.
PostPosted: Fri Oct 31, 2014 12:14 am
I think earlier in this thread I posted a video on how dettol worked for me. It was great. It had to be left overnight, but it is the best I've been able to buy here since I have never found simple green in a shop anywhere.
