Post new topic Reply to topic  [ 68 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Watching Paint Dry 11: Back in Action
 Post subject: Re: Watching Paint Dry 11: Back in Action
PostPosted: Fri May 22, 2020 2:32 pm
Thanks guys.
Still working on the conversions. The fish eyes came in so most of the tanks got them glued on. I still need to make some hatch plugs for some Salamanders and the Baneblade but that's mostly done. I also finished the Commissar plugs aside from sculpting the arms on them.
The Salamander Scouts got their autocannons this week. I ended up hacking apart a Chimerax turret, brass wire and a plastic tube that I drilled out to make the muzzle. One turret got me two autocannons. I'm still thinking on the Command, I think I'm going to try and make a heavy flamer like the Hellhound's cannon out of plastic.
The Exterminators got muzzles for their twin autocannons as well. I drilled out a plastic tube and cut away a small bit down the side so I could fit them side-by-side. They came out all right I think.
PostPosted: Sat May 23, 2020 8:07 am
This is really the sort of thing what this whole hobby is about!
Keep us inspired!
BTW, what are those purple bits in the background?
PostPosted: Sat May 23, 2020 1:17 pm
Thanks.
They're G-Tanks and a Repair Truck for MonPoc. They go with the guy in my first post.
PostPosted: Fri Jun 05, 2020 3:33 pm
Most of the building is finished, I just need to sculpt a few more arms on the Commissar markers. I also got the tanks glued to the bases. I used 30 minute epoxy for this, as I wanted something a little more supstantial that super glue.
I came up with a heavy flamer for the Salamander Command, they're a multi-melta from the plastic Squat Trikes. I reworked the barrels a little bit to look more flamer-ish.
The Baneblades are all done as well. They got twin heavy bolter sponsons, a new heavy bolter in hull turret, and new lascannon barrels that made them match the Leman Russ more.
The Stormhammers all got their heavy bolter turrets as well. They weren't too bad once I drilled out the old barrel.
Finally, here's more first pass on the color scheme. Thoughts? I was shooting for something suitably 90s GW. It's not to the level of the Eldar, more a tabletop level I think.
PostPosted: Fri Jun 05, 2020 3:47 pm
Nice work, Dave.
I'd say that scheme fits well, especially for the level of detail in the sculpt.
I would've thought that you'd forgo the salamander command tanks on principle since they add that unfair extra leader ability :P
PostPosted: Fri Jun 05, 2020 4:06 pm
No way, I had to deal with that crap for how many years? Now it's your turn to feel the raw, unbridled power that is two leader IG formations.
PostPosted: Fri Jun 05, 2020 4:50 pm
Well, at least these things can't spawn Wraithlords & Wraithguard...
Conversions look great!
Instagram: https://www.instagram.com/armiger84/?hl=en
My General Modelling Blog: http://armiger84.blogspot.com/
PostPosted: Sat Jun 06, 2020 10:20 am
If you wanna go full '90s, then go for red weapons!
PostPosted: Tue Jun 09, 2020 4:59 pm
Excellent stuff! looking forward to more colours
PostPosted: Tue Jun 09, 2020 5:33 pm
Like a repressed memory, images of that are now in my mind and I want them to go away :wah
PostPosted: Sun Jul 19, 2020 2:36 am
Not many updates but I've been slogging through the camouflage on the Armoured Company these past weeks. The base colors and shading are done, I'm now onto tidying. That should finish up this week and hopefully I can start on the highlights.
The green and tan each get a base, wash, neaten up, and two highlights. The black and metal get a wash and a highlight or two, depending on how they look.
I also painted this guy up over the course of a couple hours this week. He's a battle wizard from my last Kickstarter. He's meant to be a gold wizard/alchemist.
PostPosted: Tue Jul 21, 2020 4:10 pm
Fantastic work as always Dave - that wizard looks great, I really like the highlights.
PostPosted: Fri Aug 14, 2020 11:24 am
Nice to see some classic models painted well!
PostPosted: Fri Aug 14, 2020 4:08 pm
Thanks guys.
Not painting much these days what with the heat, but I did finish tidying up the base colors recently.
I was getting tired with the lack of perceived progress while painting the entire army though, so switched gears and just started painting the Baneblades. They just need a clear coat and flock at this point. Onto to something else next week.
PostPosted: Fri Aug 14, 2020 6:11 pm
yes! Nice ones. Are you going to leave them oldschool or muck about? Yes the heat... Not good for painting. Cleaned the airbrush today, but should probably not paint...
Users browsing this forum: No registered users and 115 guests
