Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3  Next
Partisans IG, DKOK and Orks
 Post subject: Re: Partisans IG, DKOK and Orks
PostPosted: Wed Apr 29, 2015 11:22 pm
Made a battle report of a fight between my DKOK and Uvenlords Iyanden. The pics are a bit crappy though:
viewtopic.php?f=84&t=29544&p=560972#p560972
 Post subject: Re: Partisans IG, DKOK and Orks - greenstuff press moulding
PostPosted: Sun May 17, 2015 10:58 pm
A lot has happened since the last post. Mainly I have painted up a lot of stuff for a local tournamnet at Lincon in Sweden that was arranged this weekend by Mordroten. I played with the original list but “handicapped” myself by only taking 2800 pts and two instead of three infantry companies. I won the tournament, but it was fun and exciting. The revision is necessary though and I have posted my thoughts on that in the develompment thread. viewtopic.php?f=74&t=29390&p=562918#p562918
Anyway about the modeling. In the end i moulded the "bases" fot the AA-guns with green stuff and as so often it is easier than one thinks. I started by building a "master" from a 28mm WHFB shield nad some "Axis and Allies" pieces.
Then I put some food oil on it and pressed it into greenstuff to create the mould itself.
After letting it dry for 24 hours I simly applied green stuff directly to the bit of plasticcard that I was going to use as a base and pressed it into the mould.
Result! After cleaning of the excess green stuff it was good enough for me.
Here are the uits I speed painted for the tournament. There is a alot left to do like unit marings and crew but at least they are kind of mostly done. :-)
PostPosted: Wed May 27, 2015 7:48 pm
Titan legion support from my own “Legio Corax”. 3 Warhounds - Corax Inorum, Hinatus and Domin. One Reaver - Gloriam Sepulchura and one Warlord - Deus Metallica. These where actually finished quite some time ago (around Christmas I think)
The “trenches” on the bases are for miniature d6 dice which I use to count shields and DC. I have also magnetized “steam clouds” for weapon cool down on the warhounds.
They are not entireley complete since I actually want to make and print some banners for them and possibly weather them a bit more, at least around the lower legs and feet.
PostPosted: Wed May 27, 2015 8:17 pm
Ooh those titans are aceballs! Nice job!!
PostPosted: Wed May 27, 2015 8:18 pm
Fabulous pattern on those titans!
PostPosted: Wed May 27, 2015 9:37 pm
Bra jobbat som vanligt!
PostPosted: Wed May 27, 2015 9:53 pm
Love those titans, wonderful work indeed.
PostPosted: Wed May 27, 2015 9:54 pm
brilliant titans
PostPosted: Wed May 27, 2015 11:15 pm
Love those Titans.
Ace job all round.
My Epic Army threads;
* Ad Mech (Skitarii, Cataphractii, Titan, IG Cadian)
* Marine (Xth Legion Iron Hands) TBA - soon!
* Necron (Scarab Conflict)
Batrep thread;
* Batreps (My armies being slaughtered by whomever & other battles.)
PostPosted: Wed May 27, 2015 11:46 pm
Ahhh love the partitions and checked areas.
PostPosted: Thu May 28, 2015 12:51 am
like the wholes for the dice. great idea
mattie
http://maashes.blogspot.com/
PostPosted: Thu May 28, 2015 7:06 am
Great idea for the dice tenches!
Lovely work.
D.
PostPosted: Thu May 28, 2015 8:46 am
Very nice work on those titans!
PostPosted: Fri May 29, 2015 7:42 pm
Those titans are superb!
That freehand is insane!
I love the die trenches, though you should add some barbed wire around the edge of them, or add some flooring/walling texture, so when there is no die in there they blend in more the base.
PostPosted: Sun May 31, 2015 6:43 pm
Thanks a lot for all the compliments! I will probably expand in the future with one of each Titan class to be able to play AMTL-lists.
RexHavocs suggestion about making the "dice-trenches" into real trenches sounds quite fun. Though of coure the dices are almost always there (except in the pictures for som reason or other)
Users browsing this forum: No registered users and 188 guests
