Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
What kind of glue do you use? I need help!
 Post subject: Re: What kind of glue do you use? I need help!
PostPosted: Thu Mar 05, 2015 7:54 am
i use needle tip revel polly for plastic to plastic and the loctite gel posted by deamonkin metal to metal metal to plastic
My VII Legion thread.......hopefully when you click it i actually have done something new.......
The VII involved in battle reports, probably fighting Atcho, Locknar or moridin
 Post subject: Re: Odp: What kind of glue do you use? I need help!
PostPosted: Thu Mar 05, 2015 8:35 am
carlisimo109 wrote:
Does PVA for wood work well?
I like using white PVA (the kind schoolchildren use) because you can pull the infantry off of the base pretty easily, but sometimes it's too easy. I'd like something a little stronger, but not as strong as superglue (and definitely not as strong as plastic cement).
But when it comes to superglue, the kind with a brush applicator is much easier on the nose and lungs.
The children glue I did not try but it seems too weak. The wood pva will be just fine. Just do not flood the base with because it has the tendency to shrink when it dries and can warp the base (nothing serious but keap that in mind)
If You're from Poland and play Epic PM me maybe we can play a game :)
My wargame blog: http://6mmwargames.blogspot.com/
PostPosted: Fri Mar 06, 2015 5:27 am
Well Folks,
Tried PVA not strong enough for my tastes the plastic cements didn't work because of the paint.
I'm gonna try Jewelry Glue and brush on Super Glue next.
I'll pass on results any other suggestions?
Pat (maybe I won't base them and move them one at a time ;D )
Users browsing this forum: No registered users and 157 guests
