Post new topic Reply to topic  [ 189 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 13  Next
Ian's Nurgley Appendages Redux
 Post subject: Re: Ian's Nurgley Appendages Redux
PostPosted: Tue Mar 03, 2015 4:19 pm
Awesome!
PostPosted: Tue Mar 03, 2015 5:07 pm
Looking great! Like you, I'm sure about the mechanical arms on the Warhounds though.
PostPosted: Tue Mar 03, 2015 9:32 pm
Cool thread and conversions :)
IJW Wartrader wrote:
Ilyad Chaos Goblins...Scale-wise they're a bit awkward as they're slightly small to be Warhound-equivalents but a bit big to be Defilers.
They would be fine to be Defiler proxies, they're actually a bit on the small side for them (see here for a comparison of the models most people use which are roughly scaled from the 40k models).
The Plaguehound does look a bit on the small side though. With your Defilers based on the rounded off rectangle bases I would suggest re-basing the Plaguehound onto the same size round base as the Warhound, for consistency and so it's more obvious for opponents to figure out what is what.
PostPosted: Wed Mar 04, 2015 2:42 am
Ah, I think the bases may be misleading you a little.
I have an old Warhound on a 40mm round base.
The four existing Plaguehound conversions are on 50x25mm pill bases which are larger than a 40mm round base both in longest dimension and area. Nothing else in the list uses pill bases. Here's three of the Plaguehounds next to the Warhound, with a pair of Epic40k Shadowsword conversions looking too big in the foreground due to perspective.
The Defilers are all on 25mm round discs but overflow in all directions, are mostly taller than most Defiler proxies I've seen and thanks to the tentacles look bigger on the tabletop than the ones in the linked photo - the widest is around 55mm from tip to tip.
The Wargaming Trader
PostPosted: Wed Mar 04, 2015 2:55 am
Nothing says Nurgle better than that green hue. :)
PostPosted: Mon Mar 09, 2015 10:25 pm
The Ilyad Goblin conversions will go on the back burner for now, until I've had time to think of something really good. It's not like I need more Defilers or Plaguehounds just yet.
The remaining very fine chain needed cleaning of superglue so sat in water for most of a week. That just gave me enough to do the last Spawn, herded by twin Beastmen. Or at least it would have if I hadn't cut one of the pieces too short by one link, so the left herder has a more strongly bent elbow than the other one...
I also drilled and magnetised enough bases for the rest of the Plaguebearers, although the models themselves still need plenty of cleaning up.
PostPosted: Mon Mar 09, 2015 10:31 pm
Cool!
Someone has to heard those pesky Nurgle beasts!
PostPosted: Tue Mar 10, 2015 1:14 pm
Indeed!
Some more possible models for the second Plague Zombie Infestation, or for Zombies caused by Plagueship barrages:
Although an Infestation of giant 'small' rats could be amusing:
PostPosted: Tue Mar 10, 2015 8:47 pm
These will look real cool painted up. :)
PostPosted: Tue Mar 10, 2015 10:14 pm
This is certainly the most inventive brightly coloured nurgle army I've ever seen for sure, very inventive.
PostPosted: Wed Mar 11, 2015 8:22 am
Wonderful paintjob and conversion! And this kind of green is very evil.
Orkonia: http://goo.gl/j6Q3v
PostPosted: Wed Mar 11, 2015 3:16 pm
Ta!
Courtesy of the Oldhammer Trading Group on FB, some reinforcements:
PostPosted: Wed Mar 11, 2015 8:19 pm
So are the nurglings all going to represent plague zombies?
I don't really like the Exodus Wars 6mm zombies and was wondering about other possibilities.
PostPosted: Wed Mar 11, 2015 10:01 pm
Those oldhammer figs look neat!
