Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
WWII Aircraft Recommendations
 Post subject: Re: WWII Aircraft Recommendations
PostPosted: Tue Dec 02, 2014 10:23 pm
GHQ do not put flight stand holes in their models so you need to do that yourself dependant on what stand style you choose.
Raiden do put holes in their planes which are a bit varied in size but could be adapted to normal flight stands in most cases.
Both ranges being micro scale i drilled holes in them to take 1mm brass wire. Most of the fighter size aircraft hulls would be a little narrow to accept big stands. I have looked into DZC stands for these planes and the widget attachment is a bit chunky for small planes so i adapted them so that the plane has a short length of rod fixed to it which is glued in turn into a hole drilled in the widget which then goes on the stand as normal. Bit hard to explain.
I've only done one just to test the idea i could post a pic if you want.
PostPosted: Wed Dec 03, 2014 9:19 am
Hi. Thanks for the offer, but I will have a hunt around for a suitable flight stand that is cheap and fits both sets of aircraft.
Users browsing this forum: No registered users and 109 guests
