Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
How do you paint really, really small?
 Post subject: Re: How do you paint really, really small?
PostPosted: Sat Aug 16, 2014 11:29 am
also, just to clarify I'm not an expert! just sharing the things I've learnt along the way, there are many many FAR better painters than me on this forum!!
PostPosted: Sat Aug 16, 2014 2:18 pm
In my opinion (most) people don't need really tiny brushes, what you need is a brush that hold a good point. The likes of Vaaish, Glyn, Elsemore etc can probably get the full use from a tiny brush, but in most cases a standard (GW) size with a good point is as good.
Washes and dips work well for epic, look at Onyx' work for that. Personally I drybrush/use a large drybrush-brush for pretty much everything now, except adding details and trims at the end with a standard brush – basecoating? drybrush. shading? drybrush. hard edge highlights? drybrush.
I don't think 6mm is really any different from larger scales though. Washes and drybrushes work well here, but they work at 28mm as well. If you paint well at 28mm I don't think 6mm is much different. Most fancy methods you can do at 28mm work at 6mm as well – NMM, OSL, blends etc. If you can do it at 28mm no different at 6mm, just faster to do.
Knives – ditch GW (fragile blades, expensive) and get a proper scalpel handle and scalpel blades, imo they're cheaper and better quality. 10As or 11s as Glyn said. Buy blades in bulk on amazon or similar, i go with a 100 of the two types mentioned. Change blade regularly. If it won't slice clean through a sheet of paper held vertically it needs changing.
PostPosted: Sat Aug 16, 2014 2:26 pm
Basecoat > wash (or washes) > dry brush > paint details > wash, dry brush and detail as needed to get the desired effects ... TAKE YOUR TIME ... patience Grasshopper ... patience ... ^-^
PostPosted: Sat Aug 16, 2014 4:54 pm
Scutarii wrote:
I'm going to sound blasphemous to the competent painters here but I got back into wargaming only recently and hadn't painted in about a decade. I wasn't that good at it before giving up the hobby anyway.
But, I paint to what I call 'gaming quality'. By which I mean my opponent and I are going to be about 2 feet away from the models for the vast majority of the game so paint them to look good at that distance. Belt pouches won't be visible, faces will be splotches of a different colour etc.
A well painted army is a wonderful thing to behold but if you're just starting up I'd be more concerned with getting a consistent colour scheme and painting style for the army and the formations as a whole rather than worrying about getting to great quality.
I painted Imperial Guard (http://oi60.tinypic.com/2mh7vx1.jpg)
To do this I:
1. no basecoat (I tried with and without, after leaving and coming back to the table I couldn't tell which models had been basecoated then painted yellow and which ones had just been painted yellow over the metal)
2. paint the entire model, head to toe (exception: vehicle tracks) in Desert Yellow (http://www.blackhat.co.uk/coat_darms/paintcolours.php)
3. paint brown stripes, irregularly, across the yellow painted sections (exception: not on the infantry, too small for it to matter) using Tan Earth (see link above)
4. with a thin brush paint a thin line of black through each of the brown stripes (black line thinner than the brown stripe, black line does not fill the entirety of the brown stripes)
5. paint tracks/wheels/etc. black
6. paint anything you want silver in silver (I chose Boltgun Metal)
7. for infantry paint hands/faces
8. for infantry paint helmets in a different colour (I painted all officers/commanders with orange helmets and then members of different formations with blue/red/green/brown helmets to differentiate which ones belonged to which)
9. let everything dry properly and paint a single light-medium density white drybrush all over. The purpose is to give a semi-blending of colour and break up obvious edges - basically so it doesn't just look like a series of flat colours
10. if infantry glue them to a base and use a textured paint to base them, pick a basing scheme and stick with it! If you went for a camo look (I went for desert camo) make sure the base matches the camo scheme!
Bro you really need to basecoat.... The basecoat provides the foundation for what the paint adheres to. Without a basecoat, the paint is more likely to chip and peel off, even with varnish. Good basecoat and good varnish and you're sorted for at least a decade.
PostPosted: Sun Aug 17, 2014 3:36 am
Well, lacking skill and patience, my way to paint is to pay someone good to do it for me. ;)
Users browsing this forum: No registered users and 223 guests
