Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
Water effects
 Post subject: Re: Water effects
PostPosted: Sat Feb 09, 2013 7:04 pm
I will try and dig out some photos of stuff I made using it, as I thought the stuff I did was pretty realistic..
:O
http://angelbarracks.co.uk/
PostPosted: Sat Feb 09, 2013 9:21 pm
You need to use a toothpick or similar to pull the resin to the edges or anywhere else you want it to go. It'll level itself out over time or, if you end up with a few dips or scratches, you can add another layer to fill them.
The below photos show a small thing I did, mainly as a tester. The photos aren't great as they're off my phone but you may get a slight idea. I painted the base blue/grey before adding the effect (woodland scenics).
An early stage:
The finished item:
PostPosted: Sat Feb 09, 2013 11:09 pm
Stu, that looks nice! I think I might have tried something a bit too complex too early. Seems to work a lot better on larger flatter areas where you can work the stuff.
PostPosted: Sun Feb 10, 2013 2:09 pm
I think I am done now. I posted pics in my Nurgle cult plog below. I will try to do other things as I think it has potential if used rather less radically.
Users browsing this forum: No registered users and 216 guests
