Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
Hardening papercraft
 Post subject: Re: Hardening papercraft
PostPosted: Tue Dec 04, 2012 5:35 pm
You could try printing on glossy photo paper. It's basically thin plasticard. You could also experiment with printing directly onto 0.010 in thick plasticard sheets (available from evergreen styrene).
PostPosted: Wed Dec 05, 2012 12:44 am
Great work!
I second the suggestion to use the thickest pro photo paper you can find. It doesn't have to be gloss though, matt is also available and may look better.
PostPosted: Wed Dec 05, 2012 2:49 pm
Monolith is almost done. Struggled for a while with the ribs, eventually pasting the printout to plasticard and cutting them in plastic. Huge pain. But will probably do the guns in plastic as well, as they are another 100% 2D component.
The rest is a papercraft readily available online and printed at 25% on 200 gsm photo cardstock. It came with those colors; I will gesso and repaint it, not least to strengthen it.
It is worth modifying the pattern online before printing, putting together its 3-part 3d ribs into a single 2d rib template, among other things. You can do this easily with Inkscape, as the PDF is native SVG. Inkscape simplifications might actually make a lot of the more detailed papercraft stuff scale-able . . .
PostPosted: Wed Dec 05, 2012 6:25 pm
Wow!
Seriously impressed!
Any change to obtain the mentioned file, if just to archive or spread it?!
Necrons might get back in reach (after the forumware went oop) ;)
PostPosted: Thu Dec 06, 2012 1:47 am
I used this file:
http://cs5675.userapi.com/u20557065/docs/52d5a7ce5b63/Necron_monolith_colored.pdf
If I did it again, I might do some modifications differently, so I am not including my reworked file. But you can do whatever you want to it, recolor or modify or whatever, with Inkscape. Just import the pages into a document: it will recognize them as plain SVG.
PostPosted: Thu Dec 06, 2012 9:56 am
Thanks! :)
PostPosted: Fri Dec 07, 2012 12:19 pm
Alright, all finished except for the basing colors. Generally happy with it, though the gem isn't everything I want. It is sturdy enough, probably no worse than some resin models.
Guns are simple rectangles of plasticard, nothing more. Base is 4cm square. Hope the scale is right.
PostPosted: Sat Dec 08, 2012 5:20 pm
Great finish!
PostPosted: Sun Dec 09, 2012 5:07 am
you could always swap the gem out for a plastic bead.
but that looks really nice. really really nice.
My shifting projects
Users browsing this forum: No registered users and 160 guests
