Post new topic Reply to topic  [ 86 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Imperator titan true scale
 Post subject: Re: Imperator titan true scale
PostPosted: Fri Apr 06, 2012 3:57 pm
Wowzer! I'd say the actual Epic model is slightly off from true scale, based on this project.
PostPosted: Fri Apr 06, 2012 4:31 pm
This is very cool epic, most impressive!
How do you plan on tackling the weight issue? Those legs look stong but I wonder whether they could handle the rest.
PostPosted: Fri Apr 06, 2012 4:38 pm
Could embed a cut PVC pipe as scaffolding perhaps?
PostPosted: Fri Apr 06, 2012 7:19 pm
CS, as jimmyzimms said a sort of scafolding rod through the middle, or i could just fill the legs with resin ;)
the top will be kind of heavy as im looking at using my resin towers which are fairly light but the weapons im looking at using
brass/alloy pipes for the gattling type gun and the large cannon will be copper pipe and green stuff ;)
I would love to start on the top now but it could turn out looking out of scale compared to the rest so im taking
my time and working upwards ;)
Cheers for the comments guys much appreciated, regards epic
PostPosted: Sun Apr 08, 2012 10:36 am
Hi Guys,
Managed to get a bit more done on the god machine, purchased some pipe, wood and alloy sheet and knocked
a few more bits up, also carved some wooded legs as i decided to screw the legs on one for strengh and the
the other so i can change the leg postion ;)
Next will be the head and the balcony :)
Anyway here are some progress pictures........ its getting quite big...
Next will be to greenstuff up a head and some large icons ;)
Regards epic
PostPosted: Sun Apr 08, 2012 10:49 am
Fantastic, when it's done how tall do you think it will be?
PostPosted: Sun Apr 08, 2012 11:44 am
Did anyone else see the stubby little gun between his legs and think "awwe, poor guy".
Maybe it was a cold day when the photo was taken...
PostPosted: Sun Apr 08, 2012 1:34 pm
Thought that too!
BTW, Stingray, if you're from London how come we're not playing epic regularly?
PostPosted: Sun Apr 08, 2012 3:49 pm
Hi Guys,
Yes the stubby gun is placed funny but im trying to stick to the concept artwork so trying to get in as much detail
as possible within reason without going to mad ;)
Cheers for the comments guys much appreciated ;)
As for height a rough guess as im not sure what gun im going to use on the top cannon i would say 16" or 410mm ;)
This is just as guess as i will fit the towers and the large collum and see what it pans out like.
I have moved on to the fortress balcony and taken a picture with two little sm that look pretty lost in the
scale of this creature ;D
Anyway as they say a picture paints a thousand words so you can get an idea of the scale..........
Regards epic
PostPosted: Sun Apr 08, 2012 4:58 pm
Brilliant, totally brilliant.
PostPosted: Sun Apr 08, 2012 6:30 pm
hoe lee crap
PostPosted: Sun Apr 08, 2012 6:36 pm
Hi Guys,
Finally got round to doing a bit of sculpting on the god machine, large icons i could not find so had to resort to
greenstuff, also have started building up the head its basic but its got the general shape im after when dry i will
start adding detail work ;)
Anyway here are a few pics.........
Regards epic, the emporer wills it ;D
PostPosted: Sun Apr 08, 2012 7:58 pm
Have you considered making it modular so that you could potentially later build warmonger parts which could be switched in?
You see a mousetrap, I see free cheese and a f*cking challenge
PostPosted: Sun Apr 08, 2012 9:01 pm
CTS, to be honest had not thought about it, had always just liked the old gw artwork with the imperators, so just wanted to
make one, im a bit of a scale geeh and wanted to build one to justify the machine that was shown in the old artwork,
Will have to have a look at the warmongers and see ;) its long range bombardment right ::)
all the bits will be fairly easy to remove if i went in that direction hopefully.
Few pics with some towers just to see what it would like ;D will use another deodrant lid form the top round roof aswell ;D
Will cut the towers down and paint them red and gold ;) when i put another two at the back they will be slighly higher,
the ones in the pic i will probably trim some off as they seem to high compared to the drawings ;)
Regards epic
