Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
6mm scorpion tank killer
 Post subject: 6mm scorpion tank killer
PostPosted: Sat Mar 19, 2005 6:17 pm
Drasannar,  Plastruct makes both ABS and polystyrene plastic products. ABS requires either abs glue or superglue.  The polystyrene takes regular plastic cements or superglues.
If I remember correctly the abs products are grey and the styrene is white.
The reason I prefer evergreen to plastrct styrene is, the couple times I used Plastruct I found it too be a bit more brittle than the evergreen.
I would, however, reccomend plastruct's structural line over others.  They make I-beams, L-beams, or just about any shape and scale you can imagine. (At least the used too, I have not used it in some time)  These products are ABS plastic, very strong and are great for buildings and other scenery pieces.
Just remember ABS is very hard and a pain to work with if you are using a knife.  I reccomend a razor saw and a good cut off wheel in a moto-tool.
Omnia Exeunt In Mysterium
meng...
