Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3  Next
Krawla Gargant project
 Post subject: Krawla Gargant project
PostPosted: Tue Oct 12, 2004 7:44 am
Quote (vanvlak @ 12 2004 Oct.,06:41)
UPDATE - multiple troubles - the track bits I had in mind had already been used in another project - doh! - but I devised something else instead.
And - the plastic glue I'd been working failed to work well on the drain pipe (!) which is the main hull of the Krawla: result - a couple of evenings ago I got the Krawla out to work on it and found it dismantled! The funny thing is it worked for around a week, then suddenly gave up the ghost. It is slightly warmer again here, so maybe that's the problem.
Anyway -  :angry:  - redo from start!
Jus' remeber ta use more nailz. Dat's da Orky way!  :p  :laugh:
PostPosted: Tue Oct 12, 2004 7:50 am
Nailz? Wazzit, Mojarn? New Teknologee? Da Meks use stringz theorry...
Back from oblivion (again)?
PostPosted: Tue Oct 12, 2004 7:55 am
Quote (vanvlak @ 12 2004 Oct.,07:50)
Stringz? Like da ones da feral Ork stripperz use? No wond'r yer krawla fell apart... Dey look nice but are not fer building krawlas.  :laugh:
PostPosted: Tue Oct 12, 2004 8:02 am
Quote (Mojarn Piett @ 12 2004 Oct.,08:55)
Stringz? Like da ones da feral Ork stripperz use? No wond'r yer krawla fell apart... Dey look nice but are not fer building krawlas. ?:laugh:
Feral Ork stripperz strip Imperial vehicles for bitz and use lotz of string and rope fer handling.... I thought it'ud work to build thingz wiv.
But I wuz thinkin of this weirdboy stuff, though: string theory
Ok, I know, now someone will create a mob of stripperz armed with bits of rhino and lots of rope (and string), lead by a Warphead weirdboy (sniffs! at fond memory of Warphead..) - any takerz?
PostPosted: Tue Oct 12, 2004 9:34 am
Sad I know, but I had a completly different vision when I saw the words stripper and string in the same sentence...
A project for 25mm I suspect!
I guess that's what comes from working in the city... one track mind.
Furgie
PostPosted: Tue Oct 12, 2004 10:57 am
As a professional ASW Officer, I would like to applaud your idea and suggest that more filthy submariner scum put their boats up on treads to make them easier to find!
Disclaimer: The term "filthy submariner scum" is meant as a term of endearment, and also applies to a member of my family who IS a submariner...  A cause for much personal distress... :(
Tas
PostPosted: Tue Oct 12, 2004 11:06 am
Er Tas - distress, as when you depth-charge him? God forbid! By the way, that's a thought - naval orks!
PostPosted: Tue Oct 12, 2004 11:52 am
Hmmm...there were some Ork naval landings done during the Armageddon Campaign (polar regions?) via submersibles...:;):
Tas
PostPosted: Tue Oct 12, 2004 12:17 pm
Ah, of course - back on topic!
I wonder - Gilbert and Sullivanesque ork sailors with striped vests and caps with a bright red pompom on top....not too far from Freebooterz really sjkfhbui bvhsb vb em,\cv owocmda;i93829u vs
oops - sorry for that crash - that was an idea happening - think - submarine - tracks - Orks - Freebooterz - manga pirates - loads of jolly rogers....Kaptin 'Ardlok :D  :D :)
PostPosted: Tue Oct 12, 2004 1:28 pm
Quote (furgie @ 12 2004 Oct.,01:34)
Don't feel bad, I went to the same place at first myself.  :laugh:
dafrca
              - Cities of Death, page 59
PostPosted: Fri Oct 15, 2004 9:09 am
UPDATE - PART 1 - ON SCALE
Hi all, the Krawla project, and a second project I'm working on, have set me thinking. My Krawla was (because its literally fallen apart!) 150mm long, or about 7 times as long as an elderly plastic epic scale Rhino. It's big - but is it big enough? The subs on which the Krawla is based are transport beasties, which, if correctly scaled, would be far larger - compare an M113 armoured personnel carrier to a supertanker! Now I know Epic us a scale-insensitive affair (FW vs SG model sizes; and the size of the old Leviathan and the Thunderbrick come to mind; let alone the philosphical question of how to fit ten fully-armoured marines into a Rhino - in any scale). But I wished to get this right - or at least, a bit closer to reality (reality? a super-tanker sized sub on wheels?). Whilst this means more work and redoing from start, the collapse of the old Krawla has made things easier. I'll never manage the end of the month deadline I set myself, not with the competition entry far from being ready. But at least it'll be a bigger, braver Krawla.
PART 2 - NEW KRAWLA
The sad thing is I'd really liked the old thingy; it won't be easy to retain the same shape, but I'll try. And the tracks will need a new solution, which, surprisingly, is easier to find than for my previous model. I might just rebuild the old Krawla and complete it as a smaller version - the larger special orky ops vehicle ever! Or else I could make it a bombardment vehicle, a gun-loaded Morkish Gargant based on a small Krawla. I might even make it a real sub, come to think of it... but that's beyond the Krawla project. Right now, Kaptin 'Ardlok and his Orky Freebooter krew need a new hull. And tracks.
Cheers all.
:O  :O  :O
PostPosted: Fri Oct 15, 2004 9:48 am
Quote (dafrca @ 12 2004 Oct.,13:28)
dafrca
That was the idea. I'm glad I'm not the only one with a suitably dirty imagination... }:)
And Vanvlak, if you want a _really_ insane project you could cannibalise a Revell U-99. See here for details.
PostPosted: Fri Oct 15, 2004 10:14 am
Hi Mojarn,
I've actually got the Revell USS Lionfish in the same scale - but it's too nice a kit to hand to the orks! Anyway, it's not fair building a sub out of a sub - too easy! :p
Oh, and in case you were wondering, I'd got the -ah - desired - image of Ork strippas, but sanctimoniously turned it on its head.
Blessings from Reverend Vanvlak of the Order of the Prudish Machines :p   :p
PS  - I really might build Ork Strippas some day - the demolishing sort.
PostPosted: Fri Oct 15, 2004 12:34 pm
Quote (vanvlak @ 15 2004 Oct.,10:14)
Ah, the old enginseer rule: if you have the parts to build something, use them to build something entirely else.  :laugh:
PostPosted: Fri Oct 15, 2004 12:37 pm
Correct! That's it, Mojarn! :D :D
Users browsing this forum: Google [Bot] and 161 guests
