Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
Malcador Infernus
 Post subject: Re: Malcador Infernus
PostPosted: Fri Dec 17, 2010 12:00 pm
It would make sense as a fortification piece. The tank would be set up to work like a gun emplacement, that is as much as a deterrent as anything else.
Only it is mobile and could be relocated for another battle/siege/campaign. It is hard to imagine it competing with the Hellhound as an assault flaming tank, but it could use some completely different tactics.
PostPosted: Fri Dec 17, 2010 12:06 pm
GlynG wrote:
What'd'ya reckon E&C?
Certainly easy enough to make...
PostPosted: Fri Dec 17, 2010 3:34 pm
I like it, goes well with the rest of my deathskullz stuff.
PostPosted: Fri Dec 17, 2010 4:50 pm
I'd not waste your time on such sillyness ... with so may other projects you have going on ... ;) ;D ::) 8)
PostPosted: Fri Dec 17, 2010 4:53 pm
Like scouts for the vacuum soldiers!
PostPosted: Fri Dec 17, 2010 4:56 pm
Yeah, and Vac suit Hvy Wpns, Gray aliens in various armor types, Jump Troops & Buggies, etc., etc. ... :-\ :-* ::) 8) Or if you must make an AFV ... say a Traitor/CSM Shadowsword type of thing ... 8)
PostPosted: Fri Dec 17, 2010 6:14 pm
Agreed; the full complement of electrically armoured heavies are top of my 'most keen to see models for' list, probably followed by scout ones and their flying bumpercar.
A decent proxy for this could be converted without too much difficulty from a Valdafloor, the SWR weapon hacked apart to remove the middle barrel, a trailer from an Ork Scorcha and a few bits of plastic rod.
I don't actually think it is an inferno gun; this only has two barrels, not three. I reckon it's either a twin-linked inferno cannon (odd naming convention with the two) or a new weapon.
While the fuel tank is small it is of a comparable size to the one on the crocodile so if it was feasible in real life there (which I think I saw somewhere had 80 1-second bursts) then it could be feasible here (you could also assume stronger metal plus more compressable and explosive fuel).
PostPosted: Fri Dec 17, 2010 7:44 pm
OH ... Don't forget the Egyptians both standard & Heavy ... ;D ;)
Users browsing this forum: No registered users and 188 guests
