Post new topic Reply to topic  [ 82 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
MicroWorld Games 6mm Fantasy Log
 Post subject: Re: MicroWorld Games 6mm Fantasy Log
PostPosted: Fri Dec 24, 2010 9:02 pm
thedespot29 wrote:
...the big guy on the right is the Foundationist Mobile Command Center (MCC). It is coming out along with the rest of the Foundationist range in mid January, barring any mold failures. The main hull is actually going to be resin, as the metal version proved to be way too heavy to be feasible.
If he produced them in metal, he could be arrested for selling unlicensed lethal weapons. :P
PostPosted: Sat Jan 01, 2011 6:44 pm
Just finished the first Lesser Behemoth, I washed the base on this one too soon and so some of the material flaked off, the other ones should turn out better:
PostPosted: Fri Jan 07, 2011 7:26 am
Finally finished with all four of the Lesser Behemoths, so I took some better pics:
All four:
Two buddies:
PostPosted: Fri Jan 07, 2011 10:01 am
Brilliant, i really like the pose/character of the mahout as well :D
PostPosted: Fri Jan 07, 2011 7:59 pm
Hmmm ! Nice !!! ;)
PostPosted: Mon Feb 14, 2011 1:31 am
Carrington wrote:
I've had good luck glueing 6mm metals down with Elmer's Carpenter's wood glue: use a paint brush to slop it on to the base, stick the minis down, then shower the base and minis with flocking before the glue dries.
Let set 5-10 minute, blow off excess flock, spray with water, let dry.
I cannot figure for the life of me why you'd spray the stands with water after flocking. Is this to clear the flock off the models themselves? Im about to do 40 stands of IG onto bases made by Shogun Miniatures, so the timing of this tip was excellent...
**although as I contemplate it, it seems like it would receive sand in this format, but not flock, because you'd still have to prime the models which would, of course, color the flock!**
As to the fantasy models above, I saw a copy of "Rally Round the King" at the FLGS (its by Two Hour Wargames, right, or am I thinking of something else?) but hadnt considered it an option for 6mm fantasy miniatures...
PostPosted: Mon Feb 14, 2011 3:46 pm
NB. Shogun's bases aren't going to hold to elmer's terribly well, I don't think, not porous enough, or at least so Shogun warns in his 'how to' guides. Try a test run... then try sanding the top of the shogun base for a second test run. As to the water afterwards, it's a model railroader's trick that Dave passed along. The PVA glue is water soluble. While it's still wet, it will get 'sucked' into water applied above it... meaning that some of it will end up drying on top of your flock, which means that far less of the flock will 'liberate' itself as time goes on.
dbl post
PostPosted: Thu Feb 17, 2011 9:02 am
Managed to finish up 216 little goblin warriors. I also finished basing everything except the Brutes. Next up, Armored Behemoths. I still have a lot of work to do on the orcs, but I think I will switch gears soon and do some wood elves, as I need something for the orcs to fight anyway!
Overview:
Closer:
Profile:
PostPosted: Thu Mar 10, 2011 4:33 pm
I basically finished the orcs for now, as I want to do some opponents for them so I can get some games in. There is still a lot to do on them though: Boar Riders, Cyclops, Gobbo spears, command figures. After that I still need to get the orc archers and gobbo wolf riders molded and cast. I'm currently working on a bunch of wood elf archers that I hope to finish next week.
Armored Behemoths:
Three buddies:
PostPosted: Thu Mar 10, 2011 4:36 pm
Here are some shots of everything I have painted to date...over 800 individual figs!
Carrying case, which only cost me 6 bucks:
Overview:
Right Flank:
Left Flank:
PostPosted: Thu Mar 10, 2011 7:38 pm
Now thats how 6mm armies should look!
Great work on a great scale. Makes me want to do 6mm fantasy again... noooooooo.....
Paul "TuffSkull" T.
PostPosted: Thu Mar 10, 2011 7:39 pm
Nice. I am struggling not to buy 6mm Fantasy because my wife would kill me...but pics like these sure make that resolution hard! Sooooooon!
PostPosted: Fri Mar 11, 2011 4:44 pm
:-). 6mm is much easier to conceal than 28mm.
PostPosted: Fri Apr 22, 2011 3:50 pm
Finally got around to finishing the Wood Elf archers. I finished about 192 of them. Started on the Centaur Nobles for something more fun after all those archers. Their arrows shall blot out the sun:
From head on:
And a little closeup:
Users browsing this forum: No registered users and 181 guests
