Post new topic Reply to topic  [ 329 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 22  Next
EPICS PAINTING BLOG AND CONVERSIONS
 Post subject: Re: EPICS PAINTING BLOG AND CONVERSIONS
PostPosted: Thu Jun 24, 2010 7:43 am
Athmospheric wrote:
actually, for a first attempt i think it looks nice !
I think with some sanding and smoothing, this xill turn quite good.
That might encourage me to try some sculpting of my own one day.
Cheers will give that a go and try and remove a bit more material, then base coat white and see what it looks like with a wash of ogryn brown!
PostPosted: Thu Jun 24, 2010 7:57 am
Coming along well. A nice addition to a scout stand to add character.
PostPosted: Fri Jun 25, 2010 9:09 pm
Hi Guys,
Managed to get a bit of time to clean up some of the edges on the sniper marine scout, He has turned out not to bad, the milliput is pretty easy to shave little bits off for finishing, next time i design another mini i hope it goes as well. Also im doing a little project at the moment with epic terminators and genestealers, The board will be metal hence the magnets on the bottom, they are a little oversize but are strong enough to hold on but not strong enough to damage the mini when removing if you know what i mean.
The terminator is one of my modified epic 40k plastic ones cut and shut to add a bit of charector, the same goes for the genestealer model, it was to tall with the one arm/claw in the air and made the scale look out, so the high arm got chopped out and stuck out the side to make the model scale up better and add a bit of 3D as the epic model was to flat in my eyes. The board lay out will be metal sheet with the sheet dremeled with little grid squares for the chaps to go on, Also im going to make a few objectives for this and will probably put a FW thunderhawk in for looks as the final get away
Regards epic
PostPosted: Fri Jun 25, 2010 9:23 pm
Very cool :)
PostPosted: Thu Nov 25, 2010 11:19 pm
Hi guys,
Have been trying to get some of my armies painted up recently but have been busy and the concerning pile of plastics that yet need to be painted, the pile never seems to get any smaller!
Have managed to get some of my ork army painted, have painted quite a few of the battlewagons and boyz stands already, Now just needed to paint some of the command units, quite a few of the metal 40k charectors and had only used the large dude as my war boss, have now painted up a few more and also made some orc dreads as i was not keen on the GW versions, And as i had wasted so many old SM dreads to use the guns on my terminator conversions, finally got to re use the rest of the dread to convert, simply just cut them down, fitted an orc charector and made a claw type arm!
PostPosted: Thu Nov 25, 2010 11:31 pm
Very nice stuff
PostPosted: Thu Nov 25, 2010 11:42 pm
Brilliant! Your use of torsos is exemplary.
An online epic force creator:
Armyforge
PostPosted: Fri Nov 26, 2010 12:00 am
Cheers for the nice guys, just wanted to make it look like the little green dudes where actually in them fighting not like the tin can looking 40k versions that look like trash cans with arms!
Regards epic
PostPosted: Fri Nov 26, 2010 12:23 am
Very characterful pieces!
PostPosted: Fri Nov 26, 2010 12:34 am
Fantastic
PostPosted: Fri Nov 26, 2010 4:32 pm
Very lively looking group & nice conversions! I especially like the "Popeye" look of the dreads. ;)
WAAARGH!!
The Lost & the Dipped
PostPosted: Fri Nov 26, 2010 9:07 pm
very impressive, do you mind if I link you on my own blog? (and what is the address of yours?)
http://www.mightyminiatures.wordpress.com
PostPosted: Fri Nov 26, 2010 9:24 pm
Hi Wardancer,
Your more than welcome to use the picture, I dont have a blog adress, but just right the photograph and save it windows chap and post it where you like.
Regards epic
PostPosted: Sat Nov 27, 2010 3:08 pm
Cool sculpting, dynamic conversions! Keep up the good work.
"Don't use finesse, if force will solve the problem."
- Lieutenant General Michael O'Neal
PostPosted: Sat Nov 27, 2010 5:01 pm
Groovy orks!
MoK's Painting Blog
Now Showing:
Users browsing this forum: No registered users and 122 guests
