Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
Paint stripping plastic?
 Post subject: Paint stripping plastic?
PostPosted: Thu Dec 10, 2009 3:52 am
If you are in the UK where getting Simple Green is a bit of a faff, you can give simple household Dettol a go instead. Its super cheap and has worked very well on some plastic and metal minis I've stripped recently. The scrubbing stage is a bit messy, but it takes the paint off and isn't toxic like brake fluid.
www.darkrealmminiatures.com
PostPosted: Thu Dec 10, 2009 11:24 am
Having had a go at using the ol' brake fluid, it is indeed a messy, smelly and feminine-anger inducing product.  I'm going to have a go with the dettol and the power spray I reckon.
Has anyone else had a problem using brake fluid and water? I thought I'd give my minis a quick splash of water once I'd taken them out of the brake fluid (to stop the smell) but they started going gungy and getting a white, blobby film on them.  It comes off with a bit of effort with as knife, but looks like I'll have to dunk them again.
Anyone else had this problem? Probably a reaction between water and the fluid.
Great Scott!
PostPosted: Thu Dec 10, 2009 9:12 pm
Quote: (Angel_of_Caliban @ Dec. 09 2009, 04:05 )
Quote: (ceimeifukan @ Dec. 08 2009, 11:19 )
I like fairy power spray,
does the job in 1-2 hrs, no fumes, no need for gloves etc and I've never had a  problem.
What's power spray?  :oh:  :upside:
It's widely available in the UK, I stocked up on 3 or 4 bottles from a poundshop but I've seen it in wilkinsons, morrisons, tescos's, asda ......
I've also tried brake fluid with mixed results but I really disliked what it did to my lungs and getting rid of it is a mission as it really shouldn't be washed/poured down the drain.
PostPosted: Thu Dec 10, 2009 10:03 pm
I've found synthetic (silicone-based rather than mineral-oil-based) brake fluid works fine and isn't particularly smelly or unpleasant to use. I don't know if it's safe to pour it down the drain, though.
- George Borrow
PostPosted: Thu Dec 10, 2009 10:16 pm
*Adds power spray to shopping list :grinning:
Also, nice hat Axel  :D
PostPosted: Fri Dec 11, 2009 12:31 am
no , please dont pour any kind of brake fluid down your drain. even if you do live on the other side of the ocean from me. :)
PostPosted: Fri Dec 11, 2009 3:13 pm
how do you use this fairy power spray? Just spray a lot omn p[lastics and leave it for a while? How long??
cheers
PostPosted: Fri Dec 11, 2009 4:22 pm
cheers
Probably the same way I use Simple Green. Pour some of it into a container, enough to completely cover the minis and let them take a bath for a day or two.
PostPosted: Fri Dec 11, 2009 7:24 pm
It's like a thick gel in a spray bottle, I put my mini/minis in a plastic tub and then depending on how much paint i'm trying to get rid of either give them all a decent coating or keep spraying till their submerged in gel/foam.
I've left it anywhere between an hour and about 4 I think without any problems. An hour and a half is usually good.
Users browsing this forum: Google [Bot] and 132 guests
