Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
Do metallic paints destroy brushes?
 Post subject: Do metallic paints destroy brushes?
PostPosted: Tue Mar 31, 2009 8:45 am
For a quick overview of the anatomy of a brush, different  brush materials, and different brush properties, this article should hopefully be helpful.
As I said earlier, some folks swear by syntehics for metals (their bristles break less and clean better), but I find that the brushes lose their points quite quickly (the individual hairs split or go 'fuzzy' at the tips usually). The tradeoff for me between a cheaper natural brush and a synthetic one is that I get a better result but wear the brushes out faster; since the whole point of any miniature painting brush is to get the model painted, I choose the better model result over the better brush wear. Like most plastic techologies though, synthetics are much better now than they used to be.
Malakai does make a good point though about different brushes for different jobs (aside from the more obvious 'bigger brushes for bigger areas', etc). I prefer a longer brush for detail work because the paint flows better to the small areas (hence my choice of W&N7s), but a lot of people prefer shorter brushes because the tip is stiffer and easier to control.
For fine edging, lining or flat panel work, you might find a flat brush more helpful than a round, as the shape of the brush can be guided by the edge you are looking to paint.
Ultimately, once you get past cost and wear, brushes of any type will suit people differently for a whole slew of reasons; painting styles, environments, and people's personal ergonomics are very varied afterall. The best way to find what works for you is to take the plunge and buy a few brushes of different types and qualities and work out what you like most.
Quote: (Warhead @ 08 Mar. 2009, 10:33 )
*...Blinded by awesomeness, Warhead can't see the keyboard to type his overwhelmed feelings of wonder... He hits emergency "too cool" button!...*
+++EMERGENCY! THIS IS TOO COOL! DROPPING RAY SHIELDED BLAST DOORS+++
PostPosted: Tue Mar 31, 2009 10:21 am
Well most of my Epic stuff is done with Citadel Large and Basecoat brushes. Occasionally I break out the Standard (and  once in a blue moon the Fine Detail) brush, for smaller work. Pretty pleased with results (my stuff usually gets high painting scores at tournament) but I think you are right, I should definitely try out some different brushes and experiment.
PostPosted: Tue Mar 31, 2009 1:00 pm
Quote: (alansa @ 30 Mar. 2009, 11:50 )
Yeah, I don't think I've ever used anything other than citadel brushes. Can't say I've had that much of a problem with them, but then I wouldn't see how much better things could be with natural ones.
Coverage:
My first forays into coverage where a complete disaster. Lumpy and horrid. I imagine this is quite common! After this, I practices with making the paint as smooth as possible. Thin coats with *just* the right amount of water etc. I hated to see any evidence of brush stroke or lack of smoothness. These days I have it down pretty much pat, but natural brushes would make this easier?
Detail:
All of my epic marines have appropriate tactical and chapter symbols on their shoulder pads and I've been able to apply some pretty fine detail on flags and banners (tiny thin strips of checks at the top and bottom for example)
You're suggesting that natural brushes wouldn't help much here?
Citadel brushes are natural brushes. Of course they are not on the same level as W&N brushes (I wouldn't use W&N brushes on Epic to begin with unless I won the lottery).
Synthetic brushes are the brushes with either white or yellow bristles. They have a tendency to wear out quickly (giving you a nice new dry-brush or paint mixer), but are usually really cheap and good for detail work at Epic scale.
Except to dot eyes I don't think I would consider using them on my fantasy or 40K minis.
-Malakai
PostPosted: Tue Mar 31, 2009 2:51 pm
Ah, for some reason I assumed citadel where synthetic. Shows how much I know.
Maybe I'll invest in some synthetic brushes for doing my Genesis Chapter symbols on shoulder pads and flags etc and see if they're easier to use than the cit fine detail jobbies.
PostPosted: Tue Apr 14, 2009 12:16 pm
My painting style is primarliy dry brushing and I sem to kill brushes no matter what paint or brushes I use.!! LOL
Users browsing this forum: No registered users and 121 guests
