Post new topic Reply to topic  [ 79 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Necron Monolith
 Post subject: Necron Monolith
PostPosted: Thu Jul 17, 2008 10:45 pm
Could you cast them in clear resin and then use a green LED so that its glowing inside? ( like otterman was suggesting on his other thread? )
PostPosted: Thu Jul 17, 2008 10:47 pm
Why spray it if it's to be cast?
Won't that just reduce the final quality?
PostPosted: Fri Jul 18, 2008 1:46 am
Made of pure win :love:
I love the clear resin with LED inside idea, someone has to do it once its cast up
Ideas are like soda cans, recycling sucks
If you talk to God you're religious. If God talks to you, you're psychotic
My Epic Blog
PostPosted: Fri Jul 18, 2008 7:49 am
Painting a model makes it much easier to see the problems that you have, notice areas that need filling and cleaning etc. . .
The reduction in final quality is so minimal it really isn't going to matter. The layer of spray is less than 0.05mm thick!
"Stars in my pocket like grains of sand."
www.spartangames.co.uk
PostPosted: Fri Jul 18, 2008 7:50 am
This is something that I've been planning on doing since I began making monoliths last year. I'm going to use green gel-coat (Fibre glass GRP top-layer resin) then clearcast inside that with the LED mounted within and a battery hollow in the base.
PostPosted: Fri Jul 18, 2008 12:15 pm
Ok you're 'da man on that front.  :)
PostPosted: Fri Jul 18, 2008 1:16 pm
I like to think so, I've already noticed a number of things that need sorting, there is kind of a "fence" just above the bottom sticky out corner bits, and the plates that slot in above the transport swirly thing and the circle vent on the back are wonky, they need the edges filling.
PostPosted: Fri Jul 18, 2008 1:47 pm
We're talking errors of 0.2mm here aren't we?  :))
PostPosted: Fri Jul 18, 2008 1:55 pm
Maybe as much as 0.5mm - unforgivable really.
PostPosted: Fri Jul 18, 2008 2:04 pm
You know, it's all well and good to make fun of .2mm errors until one of them hits you in the eye. :oo:
But seriously folks, I'm currently quizzing AcuCast about why my .2mm rivets didn't print, so it's easy for me to empathize with Jonluke.
PostPosted: Fri Jul 18, 2008 7:57 pm
That will look incredable i reckon!
Any idea how long it will take to make a test one?
PostPosted: Sat Jul 19, 2008 6:31 pm
Yes, a LED inside would look great.
Why not just use clear casting resin for the entire model and just place an LED inside before the resin sets?  It worked well for me with my fire prism:
www.members.shaw.ca/seebaran/My%20Fire%20Prism.htm
Keep the pics comming!
CF
PostPosted: Sat Jul 19, 2008 9:47 pm
You rock! This Monolith ist just a stunning piece of art :agree:
PostPosted: Sun Jul 20, 2008 4:59 am
just amazing
PostPosted: Wed Jul 23, 2008 1:31 pm
CF
That's a cool fire prism, but the clear-cast stuff usually picks up a bit less detail and tends towards the softer end of the castable resins, hence the GRP which is immensely tough and I do have a habit of dropping things, usually dice, but sometimes my precious little projects too.
Users browsing this forum: Google [Bot] and 131 guests
